Hey guys need some advice on where to get my r32 gtr tuned ??
Its a fresh import from Japan heared race pace is the best for gtr's but unsure anyone here tuned there gtr there? or have any other suggestions??
ta
RacePace, RE customs (see my sig), Creatd are what i can think of off the top of my head. i use RE. Ray's a top bloke and is very good at what he does. im happy with my car in his and his employees' care. a lot of people recommend racepace for gtrs and Ben does produce some monsters. depends on who you are located closer to.
Thanks for the help peepz
I dont mind travelling.. i have not heared of those tuners before only race pace... this is making things hard haha i guess i will just have to do some more research :D Another question who's the best tuner in aus for gtr's??
Best tuner in aust for GTR's? That question will only start a debate. There are plenty of good tuners. Benno is known for his work on GTR's. Ray at RE is good at what he does and the blokes at Sabbadin EAS Creatd etc would also be good at what they do. Id suggest you visit the 1s you would be interested in taking your car to and have a chat with them.
ta
I've taken my GT-R to GTech in Campbellfield for ages and they have a lot of experience with GT-Rs as well.
Whoever you ask is always going to give you a different answer, best bet is to ring a few places and have a chat and see how you go after that.
haha kool ill shut up now before Jerry gets involved :( ill figure something out..
anyone running their cars at calder on the 7th of sept?
  • 3 weeks later...
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
    • I've got MCA Blues on my V36 Skyline, and while I've managed to sort out issues with scrubbing/bottoming out by raising it a smidge and increasing the damping hardness, the rear end still sounds *super* noisy when driving on anything other than the flattest surface imaginable. It sounds like a small party of flamingos are just chatting away in the back, which makes me think there are several link points in the suspension contributing to the noise. Am I hearing dried out/worn bushings? None of it sounds like metal-on-metal, it sounds more like hard rubber squeaking on metal. It's been suggested that a bit of silicon spray on each bushing might quiet them down, but I'm not sure what material the current bushings are made of (probably factory, I imagine) and whether silicon spray will degrade that material.
    • The obvious answer here is get a ND2/3 RF with the Targa top. The red is nicer, too!
