I found this on another forum and thought it was good, so im sharing.
Here's a guide on how to carbon overlay parts of your car.
You will need the following parts -
Carbon cloth (twil looks best)
resin
acetone (if u want to clean your brushes - i use cheap ones and bin them)
plenty of latex gloves
mixing pots
measuring jug
syringe (for measuring hardner)
masking tape
Sharp scissors
Some stirrers - I use wooded spatulars
emery cloth
wet n dry 400grit to 1200 grit
polish
1) measure up your carbon cloth for the piece to be covered. Then using the masking tape tape up both sides where you intend to cut the cloth to prevent pulling the weave then cut through the middle of the tape -
2) Prep your piece to be overlayed - it should be black, if its not spray it up first so a colour doesnt show through the weave. It also needs a rub down with emery cloth.
3) brush a thin layer of resin mixed with 1% harder over the part to be overlayed then press the carbon cloth gently into place and tape up to the rear of the part to pull it into shape. You may need to change your gloves often so you dont pull the weave. Leave to dry for approx 45mins
4) Start building up thing layers of resin, you will need approx 5 layers to prevent breaking through to the cloth when sanding down. Each additional layer should be added after around 7 mins when the previous layer turns to a jelly consistency. You will now need to leave it for 1 week to fully cure -
5) you will now need to trim the excess cloth off - best tool I found was a dremmel -
BEFORE:
AFTER TRIMMING:
6) Start sanding down. work your way from 400 grit up to 1200 grit wet and dry then finish with a good quality polish for a really nice shine -
https://www.sau.com.au/forums/topic/233506-carbon-overlying/
Yeah thanks guys.
Im not sure on cost for all the materials. You should be able to get the carbon cloth from most custom fibreglasses.
I think it would be Harder then it looks but i think it can be done but u need to take ur time in doing it.
Adam
how would you go about doing dry carbon finish :S ?
Dry carbon uses a completely different production method and shouldn't be confused with wet-lay up.
I will assume you mean a raw finish which is most commonly associated with 'dry carbon' which can be achieved by just leaving the carbon with the resin and not adding a clear coat.
yeh just a matte finish without the gloss
  • 3 weeks later...
um not sure how mine is gonna turn out, my cf stitching is comptletely drifferent compared 2 ur's.
im practicing on sum pieces of wood 2morro. lol
how did u get the material 2 stick in2 the grooves? im guessing glue maybe.
my stitch's are just like lil squares side by side. ie. ooooooooooo
ooooooooooo
ooooooooooo.
i'll post a pic up 2morro. that'll b easier. lol
Sounds like you have Plain Weave Carbon Fibre. The stitch is woven in a checker pattern.
The carbon used in the pictures is 3k 2x2 Twill weave (most common carbon fibre found)
PSI Parts
how go is the carbon fiber and risen in hight heat condition
define high heat, then an answer can be provided
look into auto-claving - used with vacuum mnolds and pre-preg carbon fibre - AKA how a ferrari is built. you cant do that at home, but it will tell you the curing temps.
also - you can powdercoat fibreglass if its done correctly - so it can handle 230 deg C atleast
i was thinking of carbon fiber over laying my timing cover and igniion cover.
so it should work? :)
  • 1 month later...
Nah bugger autobarn,,,any good boat shop sells it.
No carbon fibre but heaps of fibreglass stuff.
I found this place at Warwick farm,,,I went out to have a fag at lone star and they were next door and they have lots of shops.
http://www.biasboating.com.au
Neil.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
