thanks eddy!
will keep you in mind if i need it, just tryin to stay positive that nothin major wrong and ill have it back
by friday :D
everyone keep fingers, arms, toes, legs & dicks crossed with balls please :)
  • Replies 588
Posted Images
i should know by tomorrow night if i have a front seat open in my car if someone needs a lift?lol better get off my ass and finish up some item in my car.. lol
red bull, how about the new mothers, heaps cheaper for twice as much caffeine. going to need a case for myself , i prob have to leave at 430ish to get there on time, if you see me asleep at the show you know why...lol or OD on mothers/redbull/V drink on the way might have to run around the oval a few hundred times to wear off the caffeinne...lol
anyone have room in there car (boot) for my bitchy wife or do i leave her roadside in the middle of farking nowhere...lol doubt she come anyway!!!...thank god...lol
Is she the 4 foot high blond with a flat head and no teeth? if so she can ride in my car LOL
kinda, she is 4'10 blond, with flat head and pistol grip ears....lol and a mouth that wont stop.... and NOT in that way...lol
but feel free to give me a loaner 6ft tan 23 year old hotty in exchange....lol thats what started the aurguement in the first place...lol oops
Do you want to borrow my wife then?
My daughter will be comming to Kadina with me anyway.
i find if i just get a hot as missus then i dont have to perve on others.
The grass on the otherside always looks greener.......... its human nature
Real wisdom is in reconising that what looks greener isnt always better (here ends the lesson)
PS - for every hot chick you see, there are probably 10 guys who have already been there, and moved on.
true.
i was more just being a smartass.
the grass on the other side is greener, cos i dont even have any grass.
im buying about 10 cans of rockstar orange/mango/passionfruit if anyone wants some?
if you havent had one, then you need to, they taste sooooooo good.
yes those rockstars are the best! doesnt have that 'hurting ur teeth' feel of other energy drinks. way better than the orginal rockstar. but mother is up there, getting a litre for $5 from on the runs.
its wanting what u cant have. and with the hot chick being done by 10 guys already.. no doubt im one of them.. giggidy :rofl: lol.
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
