  • Replies 133
Bags the helmet and some blue tape :P
More than one person can use the helmet and tape, there's only one on the track at a time. So get your names in
Who else has entered?
I've got a fire extinguisher with a metal bracket, just need some help mounting it, will find out what the verdict is this arvo, but if I go I'll probably drive it like a granny, for some reason the sdma track has me paranoid. Also my attessa is still fuba
Entry Forms and Supp Regs work great for me, they've upgraded them so you can tab between the fields which is a nice touch.
I've added them here, see if that helps, if it doesn't, go to another computer and try from there, I imagine there is something wrong with your pdf reader version/patches/dll's or something to that effect.
SDMA_19_Oct_Entry_Form_FINAL.pdf SDMA_19_Oct_Supp_Regs_FINAL.pdf
you can either shape a bracket to go from your drivers seat front mounts and mount the extinguisher to the brackets or go straight into the floor through the carpet.
Ok, i d/loaded a new version of acrobat reader and it worked :)
Now, for some help with the form if you dont mind please.
At the start there is a decleration part, starts with :
I ............ of address .............. postcode ........ being a financial member of the .....( what do i input in this part? im a financial member of what, my car? car club?).
cams affiliated car club name? ( what to put here if im not a member?)
sdma club membership no ( obviously i dont have one but will pay the $10 on the day, so what to put in here?)
cams licence no ( again, no cams but will pay on the day, what to put here).
Should i just leave them blank when emailing them the copy and will fill out on my printed original copy once i get there?
cheers for the help.
CLOSING DATE for Entries: 8.00pm Thursday 16 October 2008
Entry Fee: $70.00 Please Note – Late entries will not be accepted.
Declaration by Competitor: I,……… (Name of owner of car) of
Address ………………………………………………………………………………………… Postcode ………………
Being a financial member of the ……put SDMA (obtaining day/year membership on day) and being the owner of the car
described below, hereby enter my car for the above event and agree to be bound by the rules thereon which I agree,
govern the event.
Driver Details
Name …………name of driver, even if same as competitor (owner)……………………………………………………………………………
Address ……………………………………………………………………………………………… Postcode ………………
Phone (h)……………………………(w)…………………………Email: ……………………………………………………
CAMS Affiliated Car Club name ……… put SDMA (obtaining on day) …………………………………………………………………………..
SDMA Club Membership No. …………put TBA on day……………………………… (Membership card must be sighted at the event)
CAMS Licence No. put ………………TBA (obtaining on day)……………………..…… (Licence must be sighted at the event)
I'll PM my phone number, please ask if you have any more questions.
If you are a financial member of SAU, SDMA will accept that as a CAMS affiliated club, but you will still need a day licence, if you're not a member of another CAMS affiliated club, you may have to join SDMA for a year. You will need to bring your SAU licence on the day if you're going to do that.
Phone Barbara or Terry Bennett (before 9am and after 5:30pm) (H) 02 6288 7207 (M) 0412 808 134 or Email: [email protected] if you have any technical questions re: membership, categories etc.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
