How hard is it to drop the shaft to make a GTR 33 run in RWD only?
Does anyone have a step by step?
Or pics etc?
How hard is it? Anything needed to do it?
Just looking at going to an event and it has a dyno, but only a rear wheel drive dyno...
Any help would be good thanks
Ps not sure if its the right section soz!
https://www.sau.com.au/forums/topic/233703-dropping-the-shaft/
it will take about 10 min max. You need 2x12mm spanners (preferably 1 of them a ring spanner as it might be tight). Also a 14mm socket or spanner to remove the clutch slave cylinder.
just jack the drivers side of the car up and unbolt the 2 14mm bolts holding the slave cylinder on, then let that hang out of the way and undo the 4 12mm nuts and bolts on the front diff end of the front shaft. Remove all 4 bolts and pull the shaft away from the front diff and the front flange will drop down and then pull the shaft towards the front of car and the gearbox end will slide out. The gearbox hole is sealed so dont bother worrying about fluid leaking out or anything. Then rebolt the clutch slave cylinder back on and away u go.
Edited by unique1
Go buy a white and another colour paint pen and mark the edges of the shaft with the pens so you know the exact location when re-assembly is required.
I've seen the R32 boys pull a fuse and stop the 4WD that way, sorry dont know too much about the R33's.
On my 4WD laser I was told never to do this-disconnect the shafts- by plenty of people as it can really mess things up.
Have used the paint pens when removing just about everything from hoses, vacuum lines, doors, boots & tailshafts when replacing clutches and the like and its never failed there :(
and its just as easy to put back in???
Also i cant damage anything by doing this?
and no fluids at all will leak???
cheers mate
yes its as easy to put back in, no damage at all, no fluid will leak. I do this on my stagea (running gtr driveline) everytime i do dyno tuning and never caused an issue, i also drive around alot of the time with shaft removed and no problems.
  • 10 months later...
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
