General Meeting - Tuesday 16 September
thanks to all those who attended and to our guest speaker
me and tharaka did some blur motion shots ages ago on my car
using the same method joel mentioned. a camera stuck to the car with suction cups and you push the car and leave the camera on slow shutter.
http://paulr33.skylinesaustralia.com/photo...r/IMG_8957_.jpg
http://paulr33.skylinesaustralia.com/photo...r/IMG_8979_.jpg
yeah was really interesting to see the different ways/ideas and so on surrounding it all :happy:
Next meeting with a bit of show'n'tell of all things Photography - should also be pretty sweet :D
Thanks Joel!
using the same method joel mentioned. a car stuck to the car with suction cups and you push the car and leave the camera on slow shutter.
where did you find suction cups big enough to attach a car to your car?
Was first meeting for me, Good to meet a couple of the members last night.
I think i met Kaz, DuLuck, Leewah and a few others whos names I don't remember.
Btw, thanks for the cleaning cloth w/SAU emblem - always needed one of the those. Instead been buying those cheap ones from the vending machine whenever I go to wash my car.
Paul - I lol'd hard when the 2 asian guys who had just arrived when we were leaving.
i have no idea - ask tharaka or joel
i think its some sort of kit you buy (it would be on ebay)
that fits standard camera's etc
search for camera suction car harness or something
'wooooooosh'
the sound of the joke going straight over your head.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
