hey, im planning to get my windows tinted but have a few questions, first of all i know u can tint all your windows except the front, and also know they do it by shades etc.
So im planning to go the darkest legal tint which blocks 99%UV and offers more privacy and security. So that leaves me with which windows should i get tinted?
- all windows except the front
- rear window and the 2 qaurter windows at the rear
- other (sugesstions)
I asked around for some price qoutes and they vary around $200, fairly expensive for just somefilms. If you guys know any other places that do a good job and is cheap in adel please post.
Thanks in advance, nada.
https://www.sau.com.au/forums/topic/234540-windscreen-tinting/
$200 isnt that bad. its not that had to do it yourself but the back screen can be a prick cause of its size. in my oppinion well worth the money and not have the stress of screwing it up.
plus if you spend a bit to get it done you know it will be done right. nothing worse than seeing a car where the tint is all peeling off. just make sure you go to a place that offers a warrenty on the job.
+1 +1 +1!!!
and Do as much as you can, looks silly if you only do the qtr's.
Also you might be able to do the top section of the front windscreen, not sure if that's still allowed or not??
i got my window tints done, all up cost me $200 bucks which is awsome other places where charging around 270 - 320!
the tint was for the rear windscreen and all the sides, however the catch is the driver and passegnger side have to be 70% and the darkest you can go is 35% (the lower the darker)
BUT he was a nice guy and was like tell you what ill just do 35% all the way through! but if you get pulled over dont mention this place! LOL sure thing!
After the tinting was done i asked how much it wouldve cost if i wanted darker etc and he was like nuts, should have said so before same price mate as darkest as you want, you can even get a mirror tint, i was like dang too late. i could have went presidential 5% LOL
The point is i got my tinting done for a good price :)
OH and my brother who has a 2001 WRX got his front windscreen replaced from the same guys the next day because he had small stone chips on his, he got qouted for $400+ at O'briens and the place i recommended him only charged $140 and this was quality glass not that china crap O'briens gets!
If you want the contact details, just pm me. and ill arrange what ever you need :down:
So you got the legal 35% all the way around??
I got 18% all the way around. Best thing i did to my car after suspension upgrade. Awesome driving around in the middle of the day with the windows up no glare at all.
The point is i got my tinting done for a good price :(
If you want the contact details, just pm me. and ill arrange what ever you need :rofl:
Nice!, did you have tint on before hand, if so does that price include removing old tint and then applying the new, or do u need new glass if its already got tint applied?
lol, awesome driving at night in the pitch black too? lol
Err well it's not as dark as you would think and it takes all of a few moments to get used to it. Most places you drive at night have street lights anyway... therefore don't notice it. If you went somewhere that didn't have street lights it doesn't matter if you have crystal clear windows or 5% tint. Unless you can see in the dark that is :) can you?
lolz not as well as id like to, maybe i need eyes like riddick?
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
    • Ceste, jak se mas Marek...sorry I only have english keyboard. Are you a fan of Poland's greatest band ever?
