  • Replies 170
Posted Images
depends what ya would call battle spec... my car looks like a standard gtr just with rims nismo boot lip under the spoiler and a massive exhaust. if ya do see me out and about give us a way or come intorduce urself.
*edit* My car is actally rather clean and straight(when she's not dirty) so may not have been me
musta been another dude, he come out once with us.
was used as a daily so he had a few lil dents from making friends at shopping malls.
These are ones PK took
Yeah, yeah, yeah! So Pete's got a nice bike ... but can he do this with it:
:) Bikes were built for corners Sled :)
My Brutale is sexy too btw ... I have Nene's vote :(
edit: This is an old pic, the Brute has lots of CF goodies now. I've spent more on this bike, than on my two Stags. But nothing compared to what Pete spent on his piece of art :)
Edited by RubyRS4
you've already met me you sick puppy and I'm having 2nd thoughts about ever meeting you again, lol
HAHAHAHAHAHAHAHAHA!
:P
HAHAHAHAHAHAHAHAHAAHAHAHA
was not sure if u'd say it :P
told ya i would dude. :P
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
