Hi All,
Someone mentioned the change in private plates and what you are allowed to have and I couldn't find anything about this on the dpi website so thought I'd email them..
What I sent...
is it true there will be no more car specs allowed on number plates?
Like engine (RB25DET)or reference to car brands ie FORD or
HSV etc etc????
This is what i got back..
The Department has always restricted the use of words with Makes of
vehicles within the plate number. However from January 2008 the
Department have also restricted the issue of Models of vehicles that do
not have three additional characters with the model characters. The
additional three characters must contain minimum one alpha and number.
Also the additional characters must not be make or model related to a
vehicle
So who can make sense of that?
LOL
Edited by StageaGirl
https://www.sau.com.au/forums/topic/234640-private-plates/
  • Replies 60
I know you are not allowed anything with GTR in it as Nissan has set of copyright restrictions or something like that.
Mike has battled with them over this and its not possible for him to get what he wants.
Mike, shed some further light on this?
https://www.sau.com.au/forums/topic/234640-private-plates/#findComment-4110561
Hi All,
What I sent...
HSV etc etc????
vehicle
LOL
Alrighty then.....
Ok from how I've read it:
RB26 would not be ok
RB26 2JZ would be fine
https://www.sau.com.au/forums/topic/234640-private-plates/#findComment-4110643
^ what he said
My money is on the fact that the licensing dept has seen what has been happening with the auctions of private plates, and are planning a new release of limited editions to make some moolah.
fkrs :D
https://www.sau.com.au/forums/topic/234640-private-plates/#findComment-4111053
Guys,
The reason behind the rule changes, has got to do with IP
and what they believe to be their property.
Nissan and Holden have both filed lawsuits against DPI and in March DPI settled for a sum of close to 2.5Mil
in regards to a claim filed.
NISSAN have claimed IP on:
GTR
35 GTR
GTR 35
R35
Nigel even tried 23 GTR as 23 is Japanese is Ni-San
Fail boat on that one too. DPI was going to take action against Nigel on behalf of NISSAN for the claimed infringement by Nigel.
This has all been worked out now.
But it is only in W.A
As there are already 35 GTR's kicking around with similiar plates as above.
All plates currently out, will not be affected, but new plates will be harder to get through.
Clear as mud
Mike
https://www.sau.com.au/forums/topic/234640-private-plates/#findComment-4111666
I've seen [HOLDEN] before though, guy that owned it also owns a Holden dealership I believe.
Edit: Wtf Bart, that's pretty shit.. Wonder what happened to those who already have [GTS ###] plates then....
Edited by s2k12
https://www.sau.com.au/forums/topic/234640-private-plates/#findComment-4112709
Clear as mud
Mike
:banana:
https://www.sau.com.au/forums/topic/234640-private-plates/#findComment-4112765
Clear as mud
Mike
If you have good plates out now, you can auction them off for even more now to teh silly people willing to pay! Winnar!
https://www.sau.com.au/forums/topic/234640-private-plates/#findComment-4112853
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
