ok well im looking to install an amp wiring kit so i can run a sub in my 32gtr
so what i would like help with is where is the best place to run the power cable thru from the battery and into the cars cabin?
also for running the wiring into the boot?
any help would be appreciated..
and the easier the better..
Cheers,
Corey
https://www.sau.com.au/forums/topic/234749-help-installing-amp-kit/
Best place for it is to run it down the drivers side the entire way...
Get it from the battery, through the firewall, along the bottom of the door sill, up and under the rear seat then into the boot. You will have a fight getting it through the firewall. You can take off all the side skirting and what not to run it under the door and to the back seat, which you can also remove and run it through to the boot...
It sounds so simple, but unless you know where all the bolts are, it can be a prick :)
Good luck! :P
oh yeah, one more thing, don't run RCA cables and power cables together.
yeah like doof said, run the cables far apart. when i did my car, i took out the back seat, drivers seat and took up some of the carpet. a little bit extreme, but you get the piece of mind that the wiring and stuff isnt dodgy. run the rca cable next to the transmission tunnel and power next to the door sill. run the trigger cable with the rca cable.
Good luck! :P
so going thru the firewall.. that sounds hard.. lol
so theres no real easy way is there..
its an easy way;
1. Jack up the front right wheel of the car.
2. Unscrew the plastic guard liner, closest to the firewall
3. Pull down the plastic guard liner and out of the way.
4. You will now see a rubber grommet with a loom going through.
This is where you want to shove your amp wiring through.
5. Get a long screwdriver and try and poke through the rubber.
6. Feed the amp power cable through the hole you just made.
7. It will pop out to the right of the accelerator pedal. (pull off the drivers side kickpanel for easier access)
Tricky part is feeding in the amp cable as it will flex as you try push it through.
Once you've done that just run the wiring through rest of car.
Here are some pics of my installation;
Drivers side door;
Fat power cable, amp cable and front door speaker wire
Running up into the boot;
Passenger side door;
RCA cables and speaker wire
If i had to do it again, i would run the RCA cables through the centre console as its real easy to pull it off.
It was tricky to squeeze 3 sets of rca cables along the door sil lol
If you get a meaty power cable it will also be tricky running it through the door sil.
Also ive heard that taking off the black plate (seperating boot to cabin) will make the sub sound louder for you.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
