ok well im looking to install an amp wiring kit so i can run a sub in my 32gtr
so what i would like help with is where is the best place to run the power cable thru from the battery and into the cars cabin?
also for running the wiring into the boot?
any help would be appreciated..
and the easier the better..
Cheers,
Corey
https://www.sau.com.au/forums/topic/234749-help-installing-amp-kit/
Best place for it is to run it down the drivers side the entire way...
Get it from the battery, through the firewall, along the bottom of the door sill, up and under the rear seat then into the boot. You will have a fight getting it through the firewall. You can take off all the side skirting and what not to run it under the door and to the back seat, which you can also remove and run it through to the boot...
It sounds so simple, but unless you know where all the bolts are, it can be a prick :)
Good luck! :P
oh yeah, one more thing, don't run RCA cables and power cables together.
yeah like doof said, run the cables far apart. when i did my car, i took out the back seat, drivers seat and took up some of the carpet. a little bit extreme, but you get the piece of mind that the wiring and stuff isnt dodgy. run the rca cable next to the transmission tunnel and power next to the door sill. run the trigger cable with the rca cable.
Good luck! :P
so going thru the firewall.. that sounds hard.. lol
so theres no real easy way is there..
its an easy way;
1. Jack up the front right wheel of the car.
2. Unscrew the plastic guard liner, closest to the firewall
3. Pull down the plastic guard liner and out of the way.
4. You will now see a rubber grommet with a loom going through.
This is where you want to shove your amp wiring through.
5. Get a long screwdriver and try and poke through the rubber.
6. Feed the amp power cable through the hole you just made.
7. It will pop out to the right of the accelerator pedal. (pull off the drivers side kickpanel for easier access)
Tricky part is feeding in the amp cable as it will flex as you try push it through.
Once you've done that just run the wiring through rest of car.
Here are some pics of my installation;
Drivers side door;
Fat power cable, amp cable and front door speaker wire
Running up into the boot;
Passenger side door;
RCA cables and speaker wire
If i had to do it again, i would run the RCA cables through the centre console as its real easy to pull it off.
It was tricky to squeeze 3 sets of rca cables along the door sil lol
If you get a meaty power cable it will also be tricky running it through the door sil.
Also ive heard that taking off the black plate (seperating boot to cabin) will make the sub sound louder for you.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
    • So 10/10 times that code is coil packs? I mean if that's the case ill drop the $400USD or so to replace them. I didn't know these cars threw codes before the issue became an issue.
