hi, im unsure of whaty turbo would be good for me, after somthing abit bigger than a t04z..
i have a turbo now but its way too big so im gona sell it, my aim is to run consistent mid 9 second passes, im unsure if a to4z will make much more than 450rwkw on race fuel, i know they do it on pump, what would be my other options..??
cheers
denis
Garrett GT42R .... FTW
Link for Garrett GT42R http://www.turbobygarrett.com/turbobygarre...R_774595_8.html
Thats just one option of the turbo ... there are a ton of different sizes and stuff you can get. But That would be my choice on a drag car.
-Allen
still manual...
ill take your advise R31nismoid
i was just abit curious about sizes abit bigger, thats all, thoes flow maps i dont understand how to read them, i wish i could but dont know how to..
what would the t04z put out on race fuel???
Borg warner 472 is what you want. cheaper than Garret stuff and far far more reliable check out bullseye racing in the states, and also paradise racing for pricing. If you were to stay with garret 4094 and 4294 arent really that good of a turbo, your best bet would be 4202R but you will struggle launching it with a manual.
Whats wrong with the GT4094R? And do you mean Borg Warner S372? I'm not sure there is a S472 and the S372 is a completely nuts piece of kit - will make as much power as the highest power turbos mentioned here.
Sorry your right typo there, I meant the s471. A S372 with titanium wheel would be absolute killer also as both have 71-72mm comp wheels but the 3 series is t4 flange, a little easier to package over the t6 stuff.
The 4294 wheel trims are kinda arkward, they are sized down to make the jump from say a t04Z to the next size a little easier to take for the point of view of lag but if you check out the comp maps to my eyes they are sacraficing alot of mid and top end performance and you have to remember when you are talking a turbo this big thats really the name of the game.
Cheers
Cheers
Run what ive just got...
HKS T51R SPL BB....specially modified with 108mm compressor...good for 1100hp and 8's !!
In an S chassis do the right thing and run an auto (even though i hate them) they are cheaper, easier to launch , softer on the driveline and much more consistent.
Successful drag racers are not the ones that go fast...but ones that can race within a bee's d1ck of their dial in everytime.
The HKS is a great turbo, but at what cost? I can buy two borg's with titanium wheels, race covers that are polished, and specify my rear Ar for the price I was quoted on one t51, and it wasnt the spec you have mentioned.
Also forgot to mention the new borg S380, with 80mm comp wheel, 108mm inducer, titanium wheels, race cover, good for 1000hp, last time I was quoted $1999USD. Now that would be a good turbo, and I have to agree that with these big turbo's and in a drag racing application you should seriously ditch the manual.
atm i have a ITS GT80, this is good for 8 second passes aswell i was going to sell it but am totally unsure now, i have considered going auto but still am concerned about the lag..
transbrake and a shot of gas will have you leaving the line harder than any manual.
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
