Hi Guys!!!
I have 1994 S1 R33 GTST complete for wrecking, car is still complete and running due to i cant sell the complete car and i really needed the money so im going to have to wrecked.
Car had just over 100 000 klms on clock been sitting for a while now. Car is gun metal grey in colour. Car is complied.
Engine complete r33 series 1 (standard) with 100 000 klms on clock $2000 harness ecu turbo .
Complete 5 speed conversion gear box and the rest $2000
Front windscreen $100
Rear windscreen $200
Side quater window $50 each
Standard fmi with pipe $50
Cat back exhaust $200
S1 AFM $115
Quick shift kid $100
climate control $50
charcoal cannister $30 (smaller size type)
ac Fan $80
hub/fan $150
Radiator $150
rad. shroud $50
Condensor s1 $100
gaurds $100
s1 front bar $200
Front bar enforcment support $150
bonnet $250
side skirts $150 pair
s1 cluster $230 with 100 000klms...
s2 front grill $100
rear tailghts $250 complete
rear bar $100
rear garnish $70
Rear pod $80
Doors $50 each
Window motor $140
Window maganisium $50
Front Lh, RH glass $60 each
Door mirror $70 each
boot lid $100
s2 boot spoiler $150
drivers window switch $120
Passenger side $60
complete interior $200 minus rear seat......happy to separate seats trims etc.....
Adjustable coilovers $900 for the set fronts and rears
Rear diff $400
rear / front lower control arms $100 each
R34 Gt rim a set with good rubber $300
complete 5 stud conversion $800..happy to separate suspension also..........
happy to separate the shell eg Radiator support, rears quaters etc.
PLEASE ASK IF I LEFT ANYTHING OUT.
Edited by erwin_skyline
https://www.sau.com.au/forums/topic/235161-r33-gtst-complete-car-for-wrecking/
  • Replies 44
how much for complete car without motor and box?
Hi Guys!!!
S1 AFM $115
climate control $50
ac Fan $80
hub/fan $150
Radiator $150
rad. shroud $50
Condensor s1 $100
gaurds $100
s1 front bar $200
bonnet $250
s2 front grill $100
rear bar $100
rear garnish $70
Rear pod $80
Doors $50 each
Window motor $140
boot lid $100
Passenger side $60
Rear diff $400
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
