  • Replies 47
Posted Images
As I said on previous page mine has made a safe 326.8kw at southern Hi-tech dyno using N1s.... so, YEP!! :D
Having said that.... if I did have to change turbos I would definitely go the 2860s.
Edited by HOSTILE
AHH oh cheers!
ill have to keep an eye out for people selling a set
I reckon Ryan (ISC performance) was saying he would go to the 2860 - 10s if he was gonna do it again.... any comment ryan??
But yeah, seat of the pants test in shanes (puresx) GTR, those 2860s (-5s) hit pretty hard! :D
I've experienced a ride in an R32 with 2530s(=2860-5) which are quite nice, but that car was running R-Compound and already felt damn scary. Sorry, I don't think I have the balls to have something with that type of power delivery in a daily driver :D
Maybe with some more confidence and experience with a higher power level may change my mind...but I'll wait and upgrade instead of jumping in too deep
I'm currently running the 2860 -5's which are a smidge bigger than the N1's and still relatively responsive with good power.
Is anyone running a pair of 2860 -10's or HKS GT-RS (virtually the same I think) on their GTR that can comment on response sacrifice vs power gain?
The - 10's are laggy, so cams are a good idea to combat the lag but you will still get it :)
I love the -5 there very responsive and looking to get them on my car soon, Basically same as R34 N1's
There is also the HKS 2530's
that group buy is a couple of months on since he was able to get those prices still......would be worth shooting him a PM to see if he can still do that.
There is a price for -10's in that thread as N1GTR was asking about them, read through the pages :)
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
