  • Replies 73
If you have had them flow tested then obviously the fuel pressure is way way over the top or the dyno is slightly out by 30-40rwkw.
250-260rwkw is pretty much max from what I have seen from the std. RB25DET injectors with a decent/safe amount of fuel pressure pumped in.
Originally posted by INASNT
u cant be serious, 6 x 370cc injectors and 280rwkw dont add up.
u r kidding yourself if you think they are the stock ones.
gtst-vspecs car is making 368rwhp with stock injectors and I think I will make near the same once I get my wolf3d ecu in.
I got 550cc injectors in mine at the moment (waiting for the new manifold and turbo to arrive) and with around 200rwkw sometimes if i change at 7000rpm, the power fc shows the injectors flowing at around 55%. Now the 550cc injectors are 130cc bigger than the stock ones each so do the maths.
INASNT, I know where you are coming from, but this is I believe one of those times that reality and the hypothetical world dont match.
With stock fuel system I was getting up to 89% duty cycle with just over 200 rwkw.
BOOSTD is at 266rwkw with stock injectors - just upgraded fuel pump, he doesnt even have an upgraded fuel pressure reg. With increased fuel pressure and a good tune it would appear that the stock injectors can go a fair way.
Too many people exeriencing otherwise to not except IMHO
Quick question, I just found a exhaust leak on my car. Its were the turbo joins to the exhaust manifold. Its fairly big. As the turbo has moved from the manifold. Could i lose power from this leak? As i said, its faily large (guessing the size but about 1x3cm - rectangular size, possibly bigger)
:uh-huh:
will have all sorts of nasty side effects. Manifolds are usually carefully designed so as to create as little turbulance as possible - turbulance can cause unwanted back pressure and cause exhaust gasses to revert into the cylinders earlier than if it wasnt present which isnt a good thing at all. And also it is probably increasing lag, as the gasses wont be going out through the turbine.
Cant really quantify the losses, but even on a NA engine with a hole in the manifold or gasket leak it can cause noticeable loss of power.
If the exhaust leak is that big it would most definitely be hurting power, also your ears... it would be very loud. what has caused the leak/turbo to move, cracked manifold?
With a leak that big the car should be driving like a pig... is it?
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
