why would a car be uninsured on a dealer test drive
No idea Duncan. It was bought from Mitsubishi and was for sale at a non-car make dealership, the independent dealership hadn’t organized insurance for it.
Information and photos from Garry Crick Auto Group who are the local Mitsubishi/Evo dealer for my area.
Haha, thats a bit harsh.
I reckon they don't look too bad at all! Shit all over the new rex... but so does every car ever built haha
So true, Ive eaten kebabs and produced a brown baby boy that looks better then the new rex.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
