Willall Racing Buys Australia's First Official Complied/street Registered R35gtr
  • Replies 271
This sounds more like a reunion thread :)
i would rather read the old schoolers having a chat then the new schoolers whoring up every thread :ninja:
Well Mitric has been R35 converted now.....lets hear his thoughts after some time in the car today :)
bah - I didn't come down this arvo Martin, as you were supposedly 'crook' :ninja: .... I had Munro in-tow too
I reckon Steve, joined date 2004 is ftw! lol
bah, you young'uns .... the Adelaide car scene had pretty much already peaked and died before you even joined SAU :ninja: 2002 join date ftw :)
ive been these forums since 2003, just under a different name....R3125det back in the day lol...
I love that garage saurus 35 GTR, looks great.
Edited by Ryanrb25
yep i joined in 04 after i bought my 33, but i was on skylines downunder as well. and before that i had my silvia in 02 and was on ns.com which wasnt as bad back then. :ninja:
Haven't seen you for a while, Daz. Good to hear the new set-up is coming along. 500-550rwkw on E85 should be very tidy work! I might have to look into E85 for mine - not quite in the same ball park as John and yourself though! I'll be happy with 320rwkw.
I think the R35 still takes the cake as a total package though :)
Matt, not sure how well a high alcohol fuel would go in a car that is driven as often as yours isn't.
Alky loves the moisture.
yep i joined in 04 after i bought my 33, but i was on skylines downunder as well. and before that i had my silvia in 02 and was on ns.com which wasnt as bad back then. :dry:
Hehe i was a lurker on Skylines downunder but a posting member of the r31skyline forum, back in 2001 when I first got my s3 r31...
couldnt have asked for a better first car tbh
-D
i was back here in a old nick also... i put almost as much thought into the current 1... 'R33skyline' so im guesing that was 02
I reckon I could get excited about the 35 when the lighter, 2 seater, 400kw, V-Spec eventually rears its ugly head
I reckon you would probably get excited about an R35...any R35....if you drove one.
The difference truly drives like 10 years between the legacy and existing GTR platforms :P
Ahhh Nissan would love all this friendly competition between all the different tuners. I bet they just sit back thinking "they won't be able to crack this n that".
Would love to see the R35 run under 10 second 1/4s. That'd be pretty awesome to watch. Hope Willall can do it first!
Unless they go interstate, they won't be :cool:
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
