http://www.skylinesaustralia.com/forums/Ca...41#entry4131041
btw. big power engine in your rwd gtst......beautiful.
4wd FTL :)
Edited by r33cruiser
hey guys trying to figure out where and what type of oil catch can to setup on my car give me some ideas...
Heres mine that i made. It incorporates the remote oil filter as well because i didnt like the idea of having the filter mounted high on the shock tower as some people do. I also used an internal baffle system so that the maximum amount of oil is precipitated from the fumes. I dunno if it works though; i havent really got anything to compare it with.
The only thing id change is the use of the K&N breather on the outlet. The filter is fine, but id run the outlet somewhere else, like into the inner guard or down by the steering rack or something like that. The reason is because some of the oily air escapes out of the filter and i get oily build up around my fuse box. Its no biggy, but im a bit anal about it.
Also, its a tempting place to put tools and it gets scratched up. The dash 12 or 14 (i forget) braided hose and fittings cost a mint too. I think about $400 from memory, but small diameter hose looks sh1t.
Hope that helps,
Shaun.
Hi,
Simple set maybe of interest to you? I got given a catch can with 10mm piping but had already ordered in a GReddy from Nengun with 15mm piping, so rather than relocating the PCV etc. to try and make one can cover both sides of the PCV, I used the two cans. Both of them bolted up quite easily, with the use of some L-brackets from Bunnings.
Pete
I dont see the point in running those expensive empty tins (greddy and so on). You could get a Ardmona Apricot tin to do the same job and spray it :dry:
For the extra $100-$150, having a fully fabricated & baffled can made up that actually works (like Shaun) - its a very simple choice IMO.
True, but at the time I didn't know better. :dry:
BTW they were empty when I got them, but after reading the extensive posts from Sydneykid etc. on catch cans, they are now both baffled with stockings filled with stainless steel scrapers....quality stuff....lol.... :huh:
Hi,
Pete
Dude, am I seeing things or have you got that plumbed back into the intake side after it goes through the can?
Heres a place to mount if you piss off that pesky abs.
My catch can cathces the oil, there is an oil drain to empty when full, i dont want this airated and vapour back in amongst my quality oil thus no oil return.
My engine bay is a bit pressed for space as it still uses normal size battery, so we mounted it off the firewall, the can has been cut open and fitted with a small sump and baffles so that oil doesn't get caught in the filter and leak out
Sorry for late reply mate, been off working....
Yeah, it does go back into the intake pipe....I was toying with the idea of blocking it off with one of those little breather-filter things, but was worried about getting fumes and a light spraying of oil around the engine bay, as some people reckon they get. I am hoping that the blow-by is slowed enough by the baffles (stocking filled with stainless scrubbers), to drop the oil out and then flow back into the system...
Pete
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
    • Ok so i will NEED to have this sensor anyway even with Nistune (or standalone ECU) https://justjap.com/products/genuine-nissan-boost-pressure-sensor-evap-control-system-fits-nissan-r34-skyline-c34-nm35-stagea-pnt30-x-trail-rb25det-vq25det-sr20vet?currency=AUD&srsltid=AfmBOoqfxX48bW9bEwH62orcNhtBfp7ekAL0C9Ca89ySFGUiBzXfXeze Is this the correct one? And this is only thing i need? No other "things" connected to the sensor or something? I do have the wiring.
