I would gone different dumps, but for 300/320awkw it's not going to make much of a difference.
24psi peak, 8000rpm will be fine. Set the limiter for 8200 or so and fit a shift light to go off at 7500rpm.
You can do it with stock dumps, hell 380rwkw is no problem.
I put trust dumps on, the result overlayed with a car on stockers = same.
A question for the more knowledgable.
Wanting to know with a built RB26, supporting mods with -7's optimal RPM and boost setting PSI please.
Tomie Type A poncams 260 9.15
Chasing 300 or so awkws
Let me know if you need more build details
Turbo's will be out of puff by 7500rpm so you won't need to be taking it any further than that.
As for boost, set-up dependant. 20-24psi however expect the -7s to trail off to around 18psi by 8000rpm as again, they are just small.
They are on that early anyway you don't need to keep the boot in till 8000rpm :)
Which stock dumps though?
Starting with a 32, if you're after -7 power just stick 34 dumps on, for more power I would certainly choose different.
Trust being the same as stock is pretty shitty for the trust product.
As for running out of puff, sinista32 go back through this thread and look for the results I posted with dyno sheet and specs. That's a stock 73.7mm engine, you can see where power starts and drops off for yourself :)
R33 GTR. Go measure R33 and R34 dumps. You'll be surprised at what you'll find out :)
Maybe they were Tomei, there were bigger, but really didn't offer anything other than a different exhaust note to be honest.
They'd already dropped off 4psi. Probably another 1psi if 300-400rpm more was used. :)
Also do a graph with the tractive effort etc, they just start to nose well over unfortunately.
Of course they are still "holding power", mine was as well, but actually drive them and they feel outta legs by 7500rpm as both boost & torque are disappearing fast.
You'll just grab the next gear out of feel more than anything else.
Lol - just went to page one and read every post. Then got here and the graph was here.
I'm going to split difference and go 22 PSI and 7500 8000RPM.
Then drive by feel/sound.
Once again guys :cheers:
Standard sort of rebuild
Engine
Fully reconditioned head
ARP Head stud kit
ACL race series engine bearings - Big end and main bearings
JE Pistons –.87mm
Eagle rods – H beam
Tomei Poncams, Type A - IN260/EX252 9.15 lift
NITTO RB Series High Volume Oil Pump
NITTO Drag Metal Head Gasket
NITTO Metal Intake/Exhaust Gasket
Custom flat pan 9.5L sump extension with internal baffles
Custom Made 2L oil catch can
NITTO crank shaft collar
Gates Timing belt
Nismo Engine Mount Kit (engine mounts, gearbox mounts etc)
Os Giken Adjustable Cam Gears
Os Giken Twin Plate Clutch
C's Short Shift
GTR stock Gearbox
Stock manifolds
Fuel System
Denso 700cc Power Enterprise injectors
Nismo high volume fuel pump
SARD Fuel rail
SARD fuel reg
Splitfire Coil pack
Engine Management
Haltech Platinum Sports 2000
Blitz Dual SBC
Induction/Exhaust
Garret 2860-7 Turbo’s
HKS Wastegate Adjustable Actuators
Apexi Super Suction Kit (Pod filters)
HKS hard Piping kit
Custom Made Cold Air Box
TRUST FMIC with HKS Piping
GTR Stock BOV's
XFORCE Dumps
NUR Spec R cat back
Decat pipe 3.5”
Koyorad Radiator
Tune to ?
22 PSI
Limited to 8000RPM
Goal = 310awkws ?
Why would you be aiming for 310kw with that motor, chuck on some -5s with better cams. Hell that motor has some decent parts in it to take a lot more than the figure you can achieve on a stock bottom end with those turbos.
Hey Dan. thanks
I'll drive this around for a while because it's what I have got (read cash strapped). I am sure I will get bored with 310kws.
Then when cash flow allows I can try to pick up a set of 2530's and different cams - perhaps by next christmas.
I'll search the forum for results on comparisons for the -5's and 2530's.
Lag is the enemy and i drive on the street mostly.
Hey Dan. thanks
Having gone from -9s to -5s... Lag is indeed the enemy.
It was must more fun with the -9s on a a street driven car and in the hills (say 70-130km/h).
-5s IMO would be a bad choice and they are not as responsive, in between gears they are noticeably laggier too.
I also found I was dropping an extra gear everywhere to get more run. Where with the -9s you just don't because they were on earlier :thumbsup:
They don't have the big top end so they don't feel "fast", as they are very linear.
that dyno chart on this page shows -7 turbos making 22psi at about 4800rpm? thought they make full boost by 4000 give or take?
Yeah but "full boost" is a relative term, so not very useful. If that car was running 17psi boost, he would be making full boost at 4000, which is about right.
1. Just a dyno setting. Use it instead of boost.
2. As i said earlier mate you won't stop the boost dropping off.
They are small turbos, it's just impossible for them to flow that much as thier purpose is not top end :)
having gone from RS's to -5's on my stroker, they most definitely don't 'feel' as fast, but the car is alot quicker in 97% of cases. It's not all about what your butt feels... Just look down at your speedo!
We all can whack on a T88... But be belted off the line from a Camry!
My GTR is back from the tuners.
The figures read a little high im thinking - 329.8akws @18psi. Dyno Dynamics in shootout.
I'm told AFM is between 11.8 and 12. Graph has Lambda readings which I dont know the conversion factor on.
All in all not bad but from 4500 to 5200 i get what I describe as a miss/fluttering/flat feeling.
I can rev out of it/passed it - eventually but it annoys me greatly. This is generally in 3rd/4th 50% of the time.
Sometimes it occurs at lower rpm in 1st/2nd. (bit like boost cut actually)
RPM set to 8200 through the Haltech.
Be lucky to get to 6500-7000rpm under real load on the road. I expected to be out of puff around 7500 on -7's
New NGK copper bcpres7es plugs.
I suspect gapped at 0.8mm as using an experienced tuner. (Although I havent looked, yet).
New Splitfire coil packs and loom.
If you have some advice I'd be glad to hear it.
The graphs appear jerky to me, from what I have seen through this thread. ie. no smooth curve.
Told it's to do with not being able to get the Gsensor on an angle.
I couldnt get a printout displaying Power/RPM/PSI. Had to use km/h at the base :(
PS. I will be chatting with my Tuner first but I am curious and it's Sunday...
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
