  • Replies 108
Posted Images
yep fc hako is good
works well and lets you use any of the powerfc software
if your interested in checking it out ill be doing a talk on it at the next sau vic meeting SEP 21st
check out vic section for next meeting info
Awesome, so it works fine with DataLogit and all that i suppose..
Looks to just be a data connection converter so really the difference between the FC-Datalogit and FC-HAKO in terms of hardware would just be apearence i presume? Wiring would be the same and features you have access to..
Edited by antonio
FC-HAKO includes USB interface, rather than using a USB-to-RS232 converter cable which then gets converted to TTL levels with a MAX232 or similar chip.
Not sure if people use more than 2 analog inputs or the 4 switch outputs. Those are not supported.
It also supports official software (FC-Pro JP only, including analog inputs), and third party software.
It also supports firmware updating, if any bug fixes or new features need to be added to the hardware in the future.
Thanks for the info, will try and make it down to the SAUVIC Meeting and see what people think about it.. But i think im set in stone to purchase 1.
Since i plan on using it on an R33 S1 instead of having gauges on track just making a mount for it where the Head unit would sit..
  • 3 weeks later...
I've sold more overseas than to those in Australia!
That would also explain why apexi stop making ecr33 PowerFCs... everyone wants one, but no one wants to buy one :-)
David. (fc-hako.com)
the fc-hako cable is the same as the datalogit cable. they both plug into the powerfc and then plug into your laptop or PC and away you go
be sure to note fc-hako is a cable solution and datalogit is a cable and software solution
in the testing i have done it works the same and performs well and lets you use a number of applications
the cable is on their website as per bk's post and ill be adding it to the powerfc FAQ this weekend with some photos etc
there are photos on the site as well
g'day paul, quick question where can the software be sourced from if you buy the hako cable, and if so is it free, how many different types available, which is best and is it just as good as datalogit? cheers cam
every question you have is covered in the PFC FAQ
its in my signature and look for "HAKO" in the PFC FAQ
happy to test one, i use mine about 6 or 7 times a week. Would be happy to on sell them if they work as well as the fc-datalogit.
Anything new on this guys???
I'm particularly interested in its compatibility with Fc edit/datalogit .....any hicups???
trent had some issues with it working and i need to check with david as i dont know why either
this is the cable that i have , i loaned it to hamish to test with
ive used it flawlessly on my car a few times
im pretty sure it is driver related, my toughbook (running XP) is stable as but that said it has eleven billion tuning programs on it, i reckon the USB to serial driver it comes with is conflicting with another one i have installed for the old white datalogit. I use serial for catalogue now as it offers 100% (never ever had a connect issue) reliability.
For those without so many other tuning programs already loaded i reckon it will work fine, i was not willing to delete programs and drivers i use everyday (or al least 2 3 times a week) just to verify a driver conflict as it does not happen with any other interface.
When it did load up it performed flawlessly so for those looking for a cheap interface its a good option.
If you have vista i reckon your gonna struggle with the usb to serial as its a known issue... even the original datalogit usb to serial was unreliable with vista.....best bet xp.
Those that have used the FC-HAKO:
Are you connecting the cable directly to the PFC without an extension cable? Is the plug a tight fit? If so, that could be part of the issue as it should go in much farther. If you have an extension cable, please utilise that.
Also, are you removing the cable by pulling on the actual cable, rather than on the connector? Please do not do this.
If it is a tight fit or does not work any more, I'm happy to send out a replacement cable, or get it replaced in person (by John) if you're in Perth. Send an email to [email protected] and we'll organise it from there. Or if you're happy to do it, modify the connector like:
One other possibility is that the laptop may be in power-saving mode, where it might place USB devices into a lower power state after X amount of minutes of non-usage. But I am not sure if this could be causing it.
I've only had it properly tested with XP, so I am not sure when it comes to Vista / 7.
Sorry about the issues. I'm trying to figure out what is exactly causing them.
David.
Edited by _bk_
you have a toughbook! you lucky man.... how good are they! my dell c400 does me fine for now.
^^^ dont stress 98% of tuning programs bomb on vista :P
Its the main reason i backloaded XP onto my toughbook.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
