Iv been thinking of making something like this for my car at tafe. Im studying mechatronics & robotics, so this is right up my alley :P
If you use a manualised auto like the one that was in my car (click on link in my sig), this setup would be great.
https://www.sau.com.au/forums/topic/236562-shift-kit/#findComment-4140981
I found this on google, its one of their old designs, but you can see how it all goes together.
http://images.google.com.au/imgres?imgurl=...l%3Den%26sa%3DN
Howie It would be pretty easy to make up a couple of aloy paddles attached to some micro switches. it would all work on the stock triptonic.
I could look into making something like this for you if you would like.
https://www.sau.com.au/forums/topic/236562-shift-kit/#findComment-4142713
You bet your ass i'd be interested. So would most of the guys using the Stagea/R34 Tiptronic... keep me posted buddy :down:
Ok Ill let you know when Iv got something. I know what you mean about the stock buttons too, my brother has a S2 Stagea and the buttons arent the greatest.
https://www.sau.com.au/forums/topic/236562-shift-kit/#findComment-4142752
the fact that there is no physical link between the 2 freaks me out a bit.. relying on a RF link to swap gears just leaves me a bit paranoid!
I reckon you would be better off spending the $$ and getting a MV auto shift kit
I have an MV Autos shift kit. But it would be nice being able to shift it quietly and easly, plus if you convert to a full electronic shift you could fit a manual style shifter with two sensors for a sequential shifting as well.
But I agree, the RF freaks me out to.
https://www.sau.com.au/forums/topic/236562-shift-kit/#findComment-4143150
knox automatics, 395 installed, want in soft, chuck it in snow(i do in traffic so it doesnt go 1-2-1-2-1-2-1--21-2-1-2-)
Yer I know about that, what Im saying is when the auto is fully manualised like mine (see the video in my sig), the ratchet is very noisy and is sum what hard or heavy to change gears on a daily basis. If you could use an elecrtonic actuator to change it would be silent and easy, it just makes sense to run it this way (if you are fully manualised).
https://www.sau.com.au/forums/topic/236562-shift-kit/#findComment-4144214
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
