Just wondering what everyone likes about their RB30DET's.. ive been runnin round in twin cam rb30 brotherhood for around 4 to 5 years now...
I love the gut busting pull (over 1 tonne of torque well 1083nm) , the feeling of being ripped from one side of the road to the other with ease, and how tough they sound as well.
I especially like that i can drive it around off boost and be very very driveable with low compression ratio !!
so fess up ;)
  • Replies 48
Still only got a little turbo on mine for now but I came from an RB20 and the difference (same turbo) is chalk and cheese. The abundance of torque is great, being able to drive under 2000rpm and stay with traffic or not having to downshift from 5th to overtake.. fkn awesome, love it and wouldn't go back!
Oh yeah, they sound tough :bunny:
Best upgrage ive made. I had to choose wether to rebuild the 25 or go with the 30. The 30 is so much more drivable with my twin turbo setup. Would have been nice to see how a 5 speed would last with the extra torque :P
25det 5spd? should be fine, I'm not making a heap of power yet but I do beat up on it quite hard and it's holding up fine where the RB20 box died within a couple of months of the 30 going in!
3L TORQUE FTMFW!
I like mine because i built it and it works :)
I also love cruising in 5th at 80 and planting it. even in overdriven gear ratios the torque is a surge like nothing else.
things i dont like...
having to run semi slick 255 tyres to get traction and replacing them every other month :)
I like the fact that I have insane fuel economy... Although that might be because it goes through more engine problems then tanks of fuel... :(
Anyone want to change my BHG?
But, when it is running, even pig rich, the torque, to just cruise in and around easily. Then when I want some real power, plant it, and wait a second or so for boost...
Oh... And only revving to 5000RPM, only 1 bar of boost, running pig rich, no timing, and still able to pull 3rd gear roll on burnouts in the dry with 255 wide rears on...
But it's not fun when only using 1/4 throttle in the wet and having the same issues... :(
Unsure on the torque mines running in comparison to Guilt-Toys but its making ~160rwkw at 3000rpm 200rwkw at 3500rpm and 256rwkw at 4000rpm then on to 302rwkw @ 17psi @ 6000rpm. Cams really woke it up with regards to the power it made on bugger all boost.
* The forgivingness if you don't want to rev it out; short shift and it just doesn't seem to loose pace or drop off boost.
* Its pull from 60km/h in fourth gear.
* Being able to stick it to rb25 and 26's from 60km/h in third gear when they are nailing second. :)
Most of all how tough the 3ltr sounds. Since the cams went in its super deep and throbs on idle.
* Being able to stick it to rb25 and 26's from 60km/h in third gear when they are nailing second. :rofl:
Can I ask, what cam size did you end up going with?
265/263 8.9mm Tighe Regrinds. 221degree's at 0.050" - Cost me $330.
I was a little sceptical of the 265duration but Shaun/Boostworx insisted they work well in the rb30.
Fuel economy is great - A little over 11L/100.
No noticeable loss down low even though the dyno shows 2-3 kw. Once over 2k the cams start making more power compared to stock.
On the road low gear spool improved noticably. It appears to rev up and spool the turbo a tad quicker at light load (i.e low gear).
So you just had your stock Cams reground? Or you bought whole new cams, already done?
I really want some new cams, as big as I can go, and for my head, it looks like a 272 with 9.25mm lift is as large as I can get in there... My biggest issue in finding cams is finding ones to match an RB20... ;)
That's $330 per cam? or $330 total?
about to build mine!
arias forged pistons
spool conrods
n1 oil pump
metal head gasket
and all the usual stuff!
mine is auto so might have to mod gearbox at some stage!have highflow turbo on mine at the moment,rated at 260kw at the wheels!will hope to get around 340hp at the wheels and if not happy with power then will go for slightly bigger turbs!bottom should be rated at around 550hp at the wheels!being auto,the torque down low should be awesome! ;)
Lol mine isnt going yet either so at the moment my favourite thing is bragging rights to my other mate rebuilding his 25 :rant: . Secondly is the anticipation of getting it goin cos of all the stories about lighting up the rears in 3rd in fourth etc. Cant wait!!
Lol mine isnt going yet either so at the moment my favourite thing is bragging rights to my other mate rebuilding his 25 :cheers: . Secondly is the anticipation of getting it goin cos of all the stories about lighting up the rears in 3rd in fourth etc. Cant wait!!
I don't like the fact that mine will bag 3rd gear with 1/4 throttle in the wet... Makes it f**king pathetic attempting to overtake or anything...
And that's 3rd gear, doing 80km/h, go to accel and it steps sideways...
And at the cost of rubber on the rear... You cringe very quickly... :)
Need a bigger turbo. :cheers:
I find the GT30 to be really tractable. Part throttle the boost moves up with more throttle i give it. Its easy to have it just hanging on the limit so to speak.
If I don't feel like playing with the throttle - 80km/h in fourth still pulls plenty hard and will start to break traction at around 110km/h with half throttle in the wet :)
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
