hi i drive this
so i got my car tuned last week and have been having nothing but problems
and the dyno is whacked looking
current mods are: safc neo, custom t3 (stock compressor housing bored out with a bigger wheel, t3 exhuast housing), sard fpr, greddy fmic, 3inch straight pipe
can anyone tell me why there is a huge "dip" in the powerband?
Edited by sd9k
https://www.sau.com.au/forums/topic/236635-rb25-engine-troubles/
need ecu
meh alot of money went out this past month so it will have to wait
which baffles me is that my car has run perfectly fine in the past with about the same amount of hp
any other ideas?
AFM maxing out by the looks of it and hitting airflow cut. How you managed even that power on the stock AFM is interesting....
Also, you aren't running the standard injectors and fuel pump are you?
Edited by PM-R33
ya stock injectors and fuel pump
prolly back the hp down to around 230-250 or so
i've ran that power before with nps
but i think it's just way too lean
takin git back to the dyno friday
so hopefully everything will be sorted by then
or it rather be
ha
Yep AFRs are horrible, knock sensor is probably going nutso
huh?
AFR's look fine to me, sitting on 12:8 - 13:1 quite consitently. Dosn't seem anything wrong there
Gets a slight leanout as the RPM goes up, but that looks to be totally controlled by the tune as its not sharp, its slight, even and linear.
270rwhp is 200rwkw, which is what is probably the limit of the stock turbo.
And as your the aftermarket turbo, its likely reaching the AFM limit as stated. Every car is different with the AFM. Some are fine, some dont like it. Just how each seem to be really.
I'd be looking to
1. Change the fuel pump (do it regardless)
2. Upgrading the AFM
In the short term to get it driving nice, smooth and so on. Retune required there.
3. As i'd roughly say the turbo should make 340rwhp or so (hard to tell but thats what id be expecting), injectors might not be a bad investment at some point depending on how 1 & 2 go.
Cheers
remember ppl US power is about 20 to 40 % more then Aussie power. We work on true HP figures not the fairy HP that gets quoted on the other side of the globe.
that AFR is too lean. i would not let any car off the dyno with a AFR like that unless the owner knows it needs to be fixed. IMHO
Couldn't disagree with this more - so bored of hearing Aussies say that. If any dynos could be said to read "untrue", its Aussie dynos. Low reading doesn't mean more true.
Very much agreeing with that - not sure why sd9k is asking for advice and then basically ignoring it. Sd9k - you are LUCKY that you haven't blown your engine up running that kind of setup, the ECU is obviously trying to save it and with no help from the S-AFC.
A Neo by no stretch of the imagination gives you a decent proper tune, and you shouldn't be running a bigger turbo like that with stock AFM/injectors/pump. I am pretty damn sure anything else you try at this stage will not work, a proper ECU and associated fuelling changes are the first things you should be considering. Really - you should have done that before changing the turbo if limited funds are an issue.
Haven't people been tuning around that a lot lately?
More higher end tuners etc.
I cant remember exactly ;)
Okay so your saying aussie dyno's read low compared to the ones used in the US ? that would explain a few things.
and yes that car needs some serious attention. if you drive it hard like that it will blow in a matter of time. Take the advice given by these guys, computer, injectors and fuel pump is a MUST for this car or you will destroy the engine, have to buy a replacement and then still be where you started from.
Dyno Dynamics are pretty much the lowest reading dynos used anywhere. Again, that doesn't mean they are more or less accurate - they just put smaller numbers out.
i'm not ignoring advice at all man
i just don't come on here that much
but as far as the car is concerned right now
the guy who was supposed to retune the car never returned my calls
so i said f**k it and returned the boost back down to stock
and all of the corrections on the safc back down to 0 and the car runs fine like it did
and as far as the turbo on the car, it came like that when i bought it so i didn't really have a choice in the matter
but thankfully i'm coming into some moeny here next week like 1k bucks
so i'm pretty hyped
going to buy 550cc injectors, GTR fuel pump, and a z32 maf
is an ecu reflash a good idea or should i just wait to get a PFC
i've heard nothing but good things about PFC so i'm assuming that's the standard esp for RB's
but i'm open to other options as well
thank you all for the support and advice :cool:
Cheers.
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
