Morwell - Sat 11 Oct - Sau Vic Club C/ship - Rnd 7
  • Replies 68
Yeah what a great event! cheap, easy on the car, well run and a real challenge. i've seen the large freak's photos, hoping someone caught me when i had the fuel spraying out the filler neck (gotta remember to put those things back on!) are pics going in this forum or a different spot? thebuzz, i was meaning to come over and say hi, how's your datto going?
Great pics mate, thanks for posting them up.
Lagwagon, haven't done much with the Datsun lately, been doing heaps with the GT-R instead, haven't driven it for a few months... Might try and give it a run in the evening sometime soon now that daylight savings is here. Would have been a bit of fun out there yesterday hehe
What a top day.....best $75 I've spent in a while :)
Well where do I start.....a big thank you to the organizers and volunteers of the event as it was very well run. There was a fair wait in between runs but that was a reflection of the quantity of cars rather than the runnings of the day as there were 70odd cars there.
It was my first time at the new morwell hillclimb and I must say that it looked a little daunting from the carpark...tight, technical in parts and huge elevation changes. I had heard the stories of cars having stacks on it and when I was introduced to 'oh sh1t' corner it all made sense and the tyre scars on the grass confirmed the stories :0 Despite this and the fact that something like an evo or well sorted wrx has the upper hand here the track proved to be a great place to hussle a GTR around :)
I started off taking it fairly easy with a first run of 1:04something but I was able to knock time off every pass with my last run resulting in a best of 58.50. Here are a couple of incar vids:
This is my 1:00.07 pass with a good drift moment 2 corners after 'oh sh1t':
1:00.07
This is my next pass at 59.51:
59.51
and the last one I captured (vid battery died for my run after this) with a little off track excursion ;) which resulted in a 58.68:
58.68
I did a 58.50 in my last run without the little off track excursion but I do feel that there is more time to be found esp if you have adjustable suspn.
Also thanks to Ryan (Belsil80) without our little battle in the arvo I doubt we would've pushed ourselves to get the times we did (check the results to see how close we were pass after pass) but you should've known that the GTR would neva loose in the end :(
Good pics so far big bird but I want to see some sideways action ;)
agh I had to pull out due to illness, then proceeded to cut my hand open washing dishes yesterday needing 5 stitches... what a weekend
ah well there is always next year, good work on the times Ryan and Ant, very impressed
the pics are making me depressed, looks like a beautiful day/track for some fanging
It was a great day, though I'm absolutely fried... first day in the sun has taken it's toll!
Great track though, can't wait to get the 180 out onto it. Will definately give me more confidence knowing I don't have to drive it to work on Monday :P
Top shots as well Jarrod, nice one.
Nick: Nasty weekend for you mate!
Kids, there is 97 in the gallery so far. here's something i prepared earlier.
And here are the pics that i have put up.
when a massive wing isnt enough, get police strobes.....
2 wheelin dave.
dont forget to blow some hot air up my arse!
http://www.flickr.com/photos/25681729@N08/...57607956799021/
cheers!!!
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
