PM sent 2 months ago, and again 1 month ago, but not today. you think i should send another one? or maybe i should send one daily :woot:
for some reason, i still like damo. he seems like a very helpful and reasonable guy through all our correspondance................ so i'll shut up now.
Hey Tony, Adrian has advised that yours were posted, he is going into Australia Post to follow up today and you'll hear back soon.
Frankyp11 - hoodies will be posted this week, thanks for your patience mate!
Love My 32 - Anthony, ill be at old school new age, so ill bring your hoodies to you there.
DRD-OOF - Assuming you want your hoodies doof, im goin to Adrians tonight so they should be posted this week.
I think thats everyone who has requested them at this stage, let me know before tonight if you can if you want yours posted.
https://www.sau.com.au/forums/topic/237131-hoodies/page/15/#findComment-4494968
  • Replies 310
Posted Images
pm sent
https://www.sau.com.au/forums/topic/237131-hoodies/page/15/#findComment-4495310
Thanks. I got my hoodies today.
Usually, I wouldnt say anything, coz its only $50, but......
I recall somewhere along the line, there was assurance of good quality hoods being used. even some guys who picked their's up had mentioned (printing aside) they were pretty good.
One of two things has happened. Either you shop at Salvation Army, or you're afraid to say what you really think.
Coz there's no way in the world a normal person would look at these and say "yeah, i'll pay $30 or $40 dollars for this"
No fking way.
The quality of these hoodies is fkn appauling.
I wouldnt pay $8 from a chinese stall in paddy's markets for these.
The whole thing stinks of cheap. Even the zipper tab is mounted on the wrong side of the zip. wtf?
They dont fit too well either. The medium is more like a small. And the sleeves are short enough for me to think that the chinese factory was trying to skimp on some fabric, and make an extra 3c on these.
This whole venture has been a failure to the failingest point of fail, from the start, right to the very end.
But finally, it is over for me and my poor lost $50. We can walk away now, and never have to think of this again
btw, ive given the hoodie to my dog. he is currently chewing on it.
Edited by Munkyb0y
https://www.sau.com.au/forums/topic/237131-hoodies/page/15/#findComment-4506527
clearly we have heros!
did u bother to even try to organise this?
did u know wat the hoodies were gonna look like?
if ya think your the one and only do it yourself..
atleast we had a crack at it..
some ungreatful pricks on this earth!
but thank f**k i dont have to continue dealing with u!
/end rant!
ps. i dont get pissed that easy!
https://www.sau.com.au/forums/topic/237131-hoodies/page/15/#findComment-4507522
thanks rad32 for sending me the stuff...
pretty sure I had ordered a jacket but ohwell... the hoody doesnt look to bad either... they fit really nicely
the SAU does kind of let it down a bit but ill still be wearing it too cruises!!
thanks again... 2 hoodies for $60 aint bad hehe
https://www.sau.com.au/forums/topic/237131-hoodies/page/15/#findComment-4509590
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
