hey guys,
I was on my home from the mechanic, he just changed the oil filter and oil. on my way home, there was a bang noise from the left side of the engine and now no boost!!!!!!!!!!!
on the stk guage it wont go above 0 (its like the turbos will spool up but its not getting to the engine!)
i took it back to the mechanic and we checked the vacum lines on the plenum side (from the stk boost solenoid) and they are still attached. we checked to see if maybe the intercooler hose had popped off... we cant see anything around the intercooler??
please help me!!!!
https://www.sau.com.au/forums/topic/237834-bang-noise-now-no-boost-r32-gtr/
  • Replies 43
Ive had this problem before
My turbos blew once and didnt boost after ? what tiurbos are you running and were you fanging it??, but mabye thats not your case ? also had vacuum hose come out and lastly my boost controller shat itself .. could be ???
Edited by MRGTR911
stk turbos bro???
i wasnt fanging it, i dropped it back into 2nd to go around a corner, i wasnt thrashing it :)
i thought it was the turbos but i didnt get smoke from the exhaust so i didnt suspect the turbos?
could i have been wrong?
ooh. that sounds like a dead turbine wheel I hate to say.
If you have a hose off then the car usually won't want to idle well or at all.
Dead turbine is my bet, but I hope I am wrong.
If so, fingers crossed you haven't ceramic dusted the motor. Sadly this happens alot. You will find a pot or two down on compression on a test or losing compression on leak down. If it's the turbine make sure you get rid of the oil too.
Sorry i shouldve mentioned the extremely bad idle....
it goes to stall but picks up revs to keep the car alive!
its not AFMs ive just had them reconditioned to try and fix my random cutting out problem.
so the IC pipping guys?? its a stk IC, where should i look???
thanks for the help guys!
Its pretty easy, follow the pipes from the turbos to the IC, then from the IC to the plenum. Somewhere in there the pipe will be split/loose/not sealing 100%
On my one the big pipe that goes under the airbox would always come off under hard load until i got better clamps, you might find its just a shitty clamp thats letting you down
    • Welcome to !
    • As I've said elsewhere, I am using the stock intercooler piping path in the engine bay, and a return flow cooler, and making ~250 rwkW (without any effort put into trying to turn it up past there just yet) and expect to be able to make some more, and frankly, I would be perfectly happy with 260-270rwKW. This is peak road Skyline usability territory. You go past there and, sure, the car will snap necks more when it's on boost, but it will also break shit all the time, cost a (even larger) fortune in tyres, etc etc. Anyway, I also do not like the over-the-fan pipe path, and you don't have to do it.
    • I see, honestly I’m not too fussed about the looks. The only reason to go plenum is to make the piping easier instead of the classic over the rad etc.
    • Not easy to quantify wrt something like how many fractions of a second slower it would be over 0-100. But given that a 250-300rwkW car is able to do that launch sprint in 5-6 sec (and faster with appropriate tyres, and surface)..... giving up as much as a second would feel like torture. A ~450HP capable turbo is not going to make lots of boost in the 2000-3000 rpm range. So, whilst with some boost on hand it will be faster accelerating in that rev range than your engine currently is NA, it will not feel like a fast car until the boost is solidly in. You know what your car feels like right now when you open it up at 2000rpm. if you've ever been in an actual fast car, you will appreciate that the NARB25 is.... not exciting. Well, add some boost and it will be better. But shorten the intake runners and it might not be better at all. It might come out better, but it could end up feeling the same. For me, it's not the 0-X km/h sprints that matter. It is easy to fry the tyres with anything over 200 rwkW. You can't use all the power available in 1st and 2nd anyway, you have to modulate the throttle. What matters is how the car reacts when you're driving in traffic in 4th or 5th and have maybe 2000 rpm on board, and you want/need to add some speed quickly, and don't have time for the downshift. It won't make boost, it will be all NA (at the speeds we're talking about - remember how fast you're going at 2000 in 4th! and don't plan on breaking the limit by too much.) So giving away NA torque is not what I would consider practical for a street car. And retaining that NA torque builds boost faster which makes the car faster. The flashy plenum is not actually better, unless you're looking at a track car where you can keep it on the boil all the time.
    • So how much difference does it make you think? Like 1 second in the 0-100?  I was have smaller turbo so hopefully that spools quick GTX2871.  currently it’s NA so you can imagine pretty slow, but I do want fast accusation a little as there’s not many places I’ll be driving where I go over 80 even near me. So 0-60 and 0-80 targets
