R32/R33 std GTST AFM's are the same, will cap out around 200rwkw
they peak just near 5v at 200rwkw. you can stretch it to around 220rwkw ish if you like or even 250rwkw if your tuner is game but its not recommended
above say 220rwkw just get a Z32
i'd never use a stock afm for 250rwkw, thats just insanity if you ask me.
maybe tell us what your setup is then people might be able to give you more advise.
what kind of problems would you expect when running a stock afm at that kind of power level?
runs fine -- lean -- over rich --- detotanation -- boom :O
and maybe not in that order
the whole idea is to increase resolution as the inlet airflow is increased, so you have tunability throughout the rev range and flow potential of the turbo in that space.
to use it you need some thing tunable, so make the most of what ever the setup is.
hello
there are a few things worth noting before we run along a tagent
there is no given exact RWKW or PSI rating for a given AFM maxing out
when an afm maxes out or hits its celing limit in voltage it cant show the ECU any more increase in air coming into the engine (or LOAD)
i call it LOAD as most engine ECU's refer to a LOAD axis, regardless so if its map sensor or afm, they say LOAD
so once our device (be it map sensor or AFM) max out, the LOAD signal to the doesn't increase
so
scenario #1
AFM hits 5.1v and doesnt increase from this point onwards LOAD doesnt increase (lets pretend LOAD is a made up number of say 15000)
15000 units of engine load for our given ecu. lets pretend the ECU is a powerfc as these are common and our LOAD is 15000.
this doesnt mean 15000volts or anything, its just a load index. lets say the max load index possible is 20000 for any given situation.
so at 15,000 LOAD its near 3/4 on the LOAD rating (so lets say row 15 out of 20) as its 3/4s. lets say RPM is 4500rpm
so
LOAD is 15000
AFM is 5.1v
RPM is 4500rpm
so from this point onwards until the user changes gear (and it repeats) the LOAD number never increases.
it is likely more air comes into the system even though the AFM cant say to the ECU "hey more air is coming in" - because its capped at 5v
so the only change in the map co-ordinates can be is moving to the right along the "RPM" axis as the "LOAD" axis doesnt move down.
so the tuner must from this point onwards juggle the AFR's coming out and keep the timing under control
now he MUST do this for lets say 4/5's of the throttle and the throttle 5/5's as 4/5's may be enough to max the AFM
so wether the user is hammering the car or almost hammering it the user must juggle both scenarios as both use the same axis
there is where we often hear "run out of load points" as the tuner has run out of load points, so they have to juggle any possible combination
ok so now that we know what a maxing AFM means, it basically makes it a bit harder for the tuner
the engine wont go bang, it wont melt rods, pitsons, or blow up the wastegate
youll loose some tuning accuracy, and it will be a bit more for the tuner to juggle
maxing the AFM up near the top end is ok and i would call it reasonalbe
lets say you max it at 5000rpm then i would say this is ok, as not much changes from there on
now lets look at a map sensor setup
scenario #2
MAP sensor hits 2.1v and doesnt increase from this point onwards LOAD doesnt increase (lets pretend LOAD is a made up number of say 15000)
15000 units of engine load for our given ecu. lets pretend the ECU is a powerfc djetro as these are common and our LOAD is 15000.
so at 15,000 LOAD its near 3/4 on the LOAD rating (so lets say row 15 out of 20) as its 3/4s. lets say RPM is 3300rpm
so
LOAD is 15000
MAP (or PIM-1) is 2.1v
RPM is 3300rpm
it is likely more air comes into the system even though the MAP cant say to the ECU "hey more air is coming in" - because its capped at 2.1v
it is capped at 2.1v as pressure reaches target boost (controlled by the boost controller) from the time the engine reaches target boost
so lets say you hit 1.3bar at 3300rpm - from here onwards, your engine LOAD guessed by the MAP sensor setup, doesnt increase after that
now he MUST across a larger range as most engines hit target boost reasonably early (say around 3 grand) so he must do this for a wider range of thorttle and engine load "scope" but the same boost pressure etc.
there is where we often hear "run out of load points" as the tuner has run out of load points, so they have to juggle any possible combination.
so in summary, a map sensor setup it worse off and "maxes out" much earlier in the rev range -vs- an afm setup
both work ok but are tunable, will make power and so on on
its just one (the afm setup) has more accuracy and variance, thus it can use more points
some tuners say its acceptable
some say its a timebomb and so on
it all depends on the car setup and whats at stake and when does the afm max
if it maxes at 3000rpm thats bad, as its heaps of juggle/guess work for the tuner
if it maxes around 5000rpm and its a fairly low powered setup then it should be ok
by low powered id say around 250rwkw ish - over these levels it can be crucial
    • Mine is all -12, I’m running a dry sump in a billet block though
    • HG's high flow is not "bolt on". The core is shorter, moves the comp cover rearwards in the engine bay. means you have to deal with the inlet plumbing a little bit. This is probably something to consider with every "bolt on" turbo anyway.
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
