hay all
i am going to be bying a 94 gts-t turbo and wanted to know how many kws they have and how are the auto gear boxes
i would rather a manual but my gf will be driving it accasionally are they reliable/tough
https://www.sau.com.au/forums/topic/238262-gts-t/#findComment-4165469
Nothing wrong with auto, i love to relax!
both my s15 and r33 and BMW were auto's; i had to learn to drive manual when i got my gtr.
Best buy a manual though as there is a higher demand for manual cars when it comes times to sell it
https://www.sau.com.au/forums/topic/238262-gts-t/#findComment-4165682
The manual Gts-t has about 188kw and auto has about the same.. there isent really any kW diff that you would notice , but do you really want an auto? just get manual more fun + you get a upper body workout :0 , but if you wanna get auto anyway just go for it its much more relaxing and you still get that power surge when u need/want it.
https://www.sau.com.au/forums/topic/238262-gts-t/#findComment-4165878
LOL what are you whipped.. how serious is this "girlfriend" as i would bitch slap you right now if she's just a girl friend and nothing serious... cause if you's broke up.. then you've just made a decision that you'd regret..
tell the woman to get her own car lol
https://www.sau.com.au/forums/topic/238262-gts-t/#findComment-4176961
auto has alittle more torque than a manual from around 500-2500 rpm, after that the manual has more torque, standard auto will seem to accelerate from a stop/ start quicker due to the low range torque (gives you the g force acceleration), manual is more versatile, less probs, save on fuel, easier to sell, easier to thrash lol
I'd choose manual unless your usuing it as a daily city drive.....
https://www.sau.com.au/forums/topic/238262-gts-t/#findComment-4177853
I reckon manual is faster, and more fun. I tought my girlfriend how to drive manual, she loves it, maybe you should do the same. :P
was it hard lol ?
i have to do the same thing, well convince her autos are shit house in most cases. she is like " why would you want a manual when auto can do it for you"
i can't explain it to her, i've tried showing her but lol.
https://www.sau.com.au/forums/topic/238262-gts-t/#findComment-4179670
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia body...
    • This. A 3d wheel alignment is like $120...just take it to the shop. Since theres probably multiple adjustments that need to be made after changing something. Mine has front/rear lower arms, traction rods, tension rods, camber arms, toe arms, front upper arms, hicas kit, sway bars and coilovers. I measure from the edge of the bolt holes on the originals and set the same length on all the adjustable stuff to dial it as close as I could to OEM. Took it straight for alignment; it didnt feel right at all...after alignment, it feels perfect. Similarly i've just changed the springs on another car; and I still needed multiple adjustments to bring it back in spec.
    • A full Veilside kitted JZA80 Supra in Meriken park in Kobe city a few weeks back
