  • 3 weeks later...
hey. just wondering if you can fit a nissan skyline gtr r34 body kit on a nissan skyline 25gt coupe.
im saving up for a nissan skyline 25gt coupe for my first car and this is what i want to do with it.
sorry about 2 of the same posts. the website got a bit confusing
yeap altia front bar, i think thats the east bear lip for the front bumper
the rear bumper is the nismo s - tune one
not entirely too sure about the side skirts though? perhaps thats the s tune skirts?
  • 2 months later...
This is the lip from viva garage, unfortunately mine was broken in transport :( oh well. I've fixed it up now. (note: it is not attached in this photo, it is just sitting on the boxes, so i could get an idea of the look.)
  • 2 months later...
  • 4 weeks later...
Hey guys im a bit of a noob when it comes to body kits so far...was just wondering if anyone could tell me what body kits will fit on my R34 gt 4 door skyline? Might be a stupid question but is the GTR fronts the same fittings as my origional one? its completely stock atm. Cheers
Go back through the 16 pages of this thread, you should find plenty of kits for your 4dr.
Hey guys. I'm new to this website so I'm hoping I have done this right.
I have just recently bought a 4 door r34 with a stock front bar and I'm looking to buy the factory front lip.
Can anyone please help me with where would be the best place to buy one from or where I should I be looking for one? I also live in SA.
I have some pics of what front lip I'm talking about.
  • 7 months later...
If i'm not wrong its about 8k or something to put an east bear kit on. I could be wrong though, its been a long time since i've looked into it.
imho, keep your gt/gtt looking the way it is, and if you want a body kit, get something that was made for gt/gtt, keep the authenticity of it. It'll also be alot cheaper. think about 2k for sides/rear including fitting/painting?
when i first got mine i just wanted it to look like a gt-r. but after i'm so glad i didn't. mine just has a basic impul sides/rear on it, and its been lowered onto some 18" wheels. you could do something like the altia kit, very popular, so if you sell it should be all good :)
it'll make the gt-r that much sweeter when we finally get it ;)
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
