I'll no longer be at the west pre-meet, but anyone else coming from the west is obviously free to still meet with any others at the meet point and head down together...Shattered that I'm gonna miss this, hopefully I'll be at the next one!
Have some duck for me mah man!
  • Replies 130
Dammit I have to be on EXTRA good behavior, do we have to have it on Monash ground? I don't think it will go down to well with the rest of the student union if trouble does start hahahha jk
See you all there, I'll be boasting the regular cruise channel on my UHF on the way there from Caulfield campus if any of you see a silver 33 with xxx234
Will probs hit up a near by repeater as well in case ppl get lost
Decided to mock this up to get a feel of the crowd...went on posts please tell me if this is wrong really hope everyone shows! Going to be a great night!
Expecting at least 15+ cars!
Confirmed (Or Close to it)
RCHOO (Wayne) - R33 GTST
(00)SKYLINE(00) - Bringing his R34 GTR Nismo S1 (NO IFS OR BUTS...PLEASE!?)
BASTI (Niroj) - R33
R31NISMOD (Ash) - R31 GTS-R
FEMNO (Mat) - R33 GTR
GTS-T SEDAN (Nick) - R32 GTS-T Sedan
ADAM (Adam) - R32 GTS-4
JamesK (James) - R33 GTS-T S1.5 & Guest(s)
DNGRUS (Ferah) - R34 GTT
KIRAS (Guess) - Audi A4 B6 & Guest(s) (Team Ignite)
Wheezy - R31
DOGKNIGHT (DK) - R33 GTS-T S2
CHEEZ (Daniel) - R34 GT-T
AP - ?
If/But/Maybe/..../Intrested/Work/Excuse/Bla Bla Bla/Whatever (PLEASE COME!)
R33GOD - R33 GTR Vspec
LLAMA_AU (Juliette) - N15 or R34 or both...hopefully
KRZYSIU (Kris) - R33 GTS-T S2
LIL_LUCKY (Chad) - R32 GTS-T
HTIAL (Laith) - R33 GTS-T
B3ZA (Bez) - R34 4
RICHAR (Richard) - R33 GTS
AL (AL) - R33 GTS-T
ADAM -__- (Adam) - KE70
SHOTGUN!
Jeaneen - KIRAS'S Wingman...
Nick - KIRAS'S Wingman....
Vish or Sarah or Both - JAMESK'S Wingman....men...wo
...NEEDS DRIVER!
DEZZ (Michael) - Wingman
Cant......(WHY?)
MP_R33 (Ross) - R33 GTS-T MP - ....Comeon!!!
eMsta (Matt) - Jazz - You've used that excuse already!
LEANBAC (Allen Paul) - R32 4 - .....Comeon!!!
Edit: THANKS BASTI!
BASTI (Niroj) - R33
FEMNO (Mat) - ?
Wheezy - R31
HTIAL - R33 GTR
B3ZA (Bez) - R34 4
AL (AL) - R33 GTS-T
SHOTGUN!
AP - KRZYSIU'S Wingman...
...NEEDS DRIVER!
Cant......(WHY?)
a few things. kris is riding with ap (which means ap is coming), nick might be riding with kiras, laith (htial) has a gtst and femno has a gtr. well done other wise :)
When you say nick do you mean R33 sedan nick? And whats AP driven?? Thanks for the corrections
Shh... ...believe it's a GT-R and it will be...
Cant......(WHY?)[/b]
My Jazz is top secret - i only bring my R33 gtst to these meets
a few things. kris is riding with ap (which means ap is coming), nick might be riding with kiras, laith (htial) has a gtst and femno has a gtr. well done other wise :P
GTST Sedan is Nick. AP drives a 32 4 door GTSt too.
i have a car its got 4 wheels
however its sitting in the garage and ill be rocking up in a telstar :P
:P Bring it anyway !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :P
:cool: LOL!
Actually its my friend Han, his car. You know the one off the Just Cars Add... And you probley saw it at the Auto Salon.
BASTI (Niroj) - R33
Wheezy - R31
AP - ?
B3ZA (Bez) - R34 4
AL (AL) - R33 GTS-T
SHOTGUN!
...NEEDS DRIVER!
Cant......(WHY?)
Edit: THANKS BASTI!
LOL!
Good write up there JamesK. Makes things a lot more interesting.
Will see about the S-Tune, if not a R32 GTR or a V-Spec R34 GTR.
Cool!
haha, R34 only. I may rock up to an SAU meet in the Pulsar one day for shits and giggles.
I will be there! To wash or not to wash the car?
Edited by llama_au
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
