  • Replies 77
Very tidy Scott, but what's the red switch for if you don't mind my asking.
for my NOS bottles...... hahahaha nah just kidding..... its for my boost controller. Have low set on about 8psi and high on 12-13psi... love that switch deffinately comes in handy =]
Those pics are pretty old.. I tooks a few more the other night but only difference is shortened gear knob and Nismo badge
hey mates..just found this guy from south east melbourne selling really nice interior for r33 and r32, friendly and patient guy. cost me around $120 but havent fitted in yet, as i'm busy for the x'mas. Anyway if anyone is interested, feel free to drop him an email at [email protected] "ekkoperformance"..cheers
the whole interior cost you $120? what does the package comes with
Whole set comes with:
2 x Front door trims, 1 passenger 1 driver
2 x Rear arm rest trims, 1 passenger 1 driver
1 x Centre console lid
1 x Glove box trim
1 x Set of instructions on how to install :P
My interior
Just thought it should be known that this R33 has a FULL Cusco roll cage (from what I can see) perfectly integrated to the standard trim... this is really beautiful in it's own right... how much police trouble have you had from this?! :rofl:
PSI Parts also noticed this, as I would expect :P
shits all over my painted interior n shit
  • 1 month later...
Just thought it should be known that this R33 has a FULL Cusco roll cage (from what I can see) perfectly integrated to the standard trim... this is really beautiful in it's own right... how much police trouble have you had from this?! :D
PSI Parts also noticed this, as I would expect :)
Sure did :banana:
Just going back to the cage, would this be CAMS approved? I seem to remember CAMS only allows two bends in each corner bar for structural reasons? (Yes I can't be bothered looking at my CAMS manual)
Yep, cheaper rego too :P
So am I right in saying you can rip your rear seats out and all you have to do is re-register your car as a 2 seater.
Or is there more involved..ie; RTA inspections, etc.
I wanna rip out everything I can!
If you remove the rear seats and register as a 2 seater, the rear seat belts need to be removed as well as far as I know
    • Input shaft bearing. They all do it. There is always rollover noise in Nissan boxes - particularly the big box. Don't worry about it unless it gets really growly.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
