Yes thats right... the next time you are down the shops and decide to buy a big bag of Allens Party Mix think twice. These things need a warning label on them.
On the weekend i thought i would indulge in some of my favourites like Coke Bottles, Teeth and Rasberries. If only i had known.
The first few went down a treat... sweet and sugary, just what you need when you wake up.
However, while holding my son i thought i would throw a few in at once and go down to the lounge floor where all his toys are spread out and engage in some ever entertaining block building with him.
While on the ground he came over and jumped on my guts as i was inhaling and as i knew what he was about to do i sucked in my gut and tensed my stomach (hes now over 14kgs and 80cm which for an 11 month old is quite large) which resulted in me inhaling large chunks of said lollies down the wrong pipe.
Of course he found this extreeeemely amusing and did it again for good measure and continued to piss himself laughing til he eventually fell off me.
By this time i had managed to finally clear my aorta of all foreign objects and continued on with our fun and games.
After about 5 minutes i started getting that feeling like when your getting a really bad cold or flu and the back of your nasal passage starts burning. 3 hours later the family decided we would go to the shops and whilst in the car the pain started getting really bad, more so then any other cold or flu I've had. So, as you do, i snorted back as hard as i could and sucked into my mouth one very large peice of Coke Bottle... mmmmmmmm sweetest grot ive ever sucked back.
So there it was... the cause of all that pain for 3 hours was a sweet and so called harmless 10c treat hell bent on destruction burning away at my nasal lining.
We shouldnt be sending troops to Iraq to look for WMD's, its the Allens lolly factory we need to be searching! So make sure not to partake in any physical activity while eating these melevalent little weapons of mass destruction.
Youve been warned!
(just thought id share... see i still contribute to these forums :thumbsup:)
https://www.sau.com.au/forums/topic/239014-public-health-warning/
Funny story,very entertaining...
Just to allay any fear or confusion for other readers, the aorta is a part of the vascular system (artery) and not a part of the respiratory system.
Glad you survived to give your cheeky boy a clip over the ear :)
lol
yeah i mean the other one... the oesophagus
lol mate wrong again, the oesophagus is where food SHOULD go.. sounds like the coke bottle was lodged in your trachea (or 'wind pipe')
anyway im gald you made it out alive!
iv'd had the crap happen to me, burning i know food has some how worked it way up to the back of my nazel passage. but then there is the other weird thing happens , i try to had to hawk it out or snort it back that i then start to hic-up ... then it just starts to be frustraighting and anoying.... Just my 2 cents :D
you story is a good read for a laugh !
I think the moral of this story is that you shouldn't be allowed to reproduce narkeh.
bonus points for nark-jnr for kicking you in the guts so early on in the game.
LoL @ the terminology confusion..
I am also craving coke bottles haha.
lol well its better then gender confusion like my little dwarfen sri lankan monkey friend... shan :(
this is why im not a doctor... id be like Dr. Nick from the Simpsons... /removes heart... "there, no more stomach pains for you"
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
