Michael, yours sounded tough as out there today! Noticed smoke come from underneath the car under deacceleration/down shifts, I presume power steering fluid dropping on the exhaust?
You're right Luke, it was the power steering fluid.
  • Replies 71
Nice program^^^. How did it create the map of mallala? Through google maps etc or just traced your path? You planning to head out agin soon, definetly want to see this thing in action!
Ryan
Looking at it, I would say it uses GPS tracking technology.
210kph thru the kink? Too bad, just 15kph shy of what my bike can do :banana:
Joeleo - do you mean a trackskill car because i wouldn't put them in the same class as a super v8
210kph thru the kink? Too bad, just 15kph shy of what my bike can do :P
do you always have to compare apples to oranges
like children at a competition,we all know how fast bikes go,this sites called skylines not bikes r us,otherwise a lot of people would have heaps of stuff to say,accidents and all that,keep it constructive,this sites getting worse,we all know who the try hards and posers are,dont stoop to that level guys
Damo ... you've changed man :/
j/k point taken :P I'm just still 'switched on' from the GP weekend.
No bike does 225kmh through the kink......
"no bike" is a pretty big statement.............Rossi or Stoner may have something to say about that on their lightweights ;)
some of these guys below do similar bends on the Isle of Mann at 260kph on one wheel.........unfortunately this guy didn't quite make the bend, ouch!! :/
Isle of Mann bend at 256kph
Ryan
At a guess it made the map with a G sensor, my go kart data logger would do the same thing
"no bike" is a pretty big statement.............Rossi or Stoner may have something to say about that on their lightweights :)
A current spec litre bike will exit the top of turn 3 at around 60km/h and then have 200 metres to accelerate to peak speed before gentle braking or a complete roll off into the kink. There is no such thing as holding a 180-200ps superbike through the kink flat on conventional road tyres, and there are very few that could roll through there at a genuine 230km/h. The more powerful the bike, the more the back straight gets divided into two straights with a bend in the middle :)
Mallala is always the same story. It seems no matter who you speak to, or how slow their lap times are the bike/car car goes into the kink at 180 - 200km/h. Fact is an R35GTR, one of the quickest production cars you can buy, and capable of an 11 second quarter in stock form, fires out of turn 3 with full traction and enters the kink at an ACTUAL 180km/h, absolutely flat to the boards. Data logging like this, rather than a quick glimpse at the speedo, tells the whole story, even if it doesnt sound so cool :O
Edited by Martin Donnon
I think you have a point there given the wheel slip/loss of actual speed but I for one would love u to lend ruby ur tracking kit.... looks hardcore good (certainly looks better than the home made telemetry system im building)
-D
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
