  • Replies 44
erik i think you are far from newbie now mate, and you LOL alot hey, but I for one love any thread where you start chatting oh yeah and especially if rob passes by
anyways Rian I agree your interior is da schnizit bro
FORSHEEZEE MY NEEZEE, yeah Zanda i reckon for the $600 saving dood we can retrim it again if it fades in a coupla years
Paul you retrimmed all of our interiors so why you lying to Erik?
Jokes very nice of you to help out, actually i would as well if i had your engine in my engine bay *hmmm lots of driving*
Alex, I spent ages looking for car grade leather when I got mine, but all of the upholstery places told me all the leather is the same. I got mine off RYAN, no problems yet. The car leather cleaners have the treatments in them to protect from the sun, so I clean it once a week now, once it is hot I will do it twice a week. One of those things only time will tell.
angel RIAN is going to be pissed you spelled him RYAN you of all people
oh the shame LOL :P)
Umm now yeah Angel i agree
I can organise leather protection etc for anyone if needed purdy cheap
Hey PIMPIN (adrian) you and bam bam are representin without permission i c
Erik if i was you man i would get some dash inserts chromed or gold chromed (cos your car is black) or sprayed to look like aluminium etc and then get the gear boot and handbrake boot changed and do your door inserts a different colour, but keep it neutral like silver gray beige or something like that. that way the car looks modern and not overly done.
anyways lata
RiaZ
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
