sweet... do you have enough balls in the rest of your fuel sys to handle 400 on e85?
would be nice to see you crack it if you ever decide to upgrade injectors.... i mean there's gotta be someone you could swap with for a small cash advancement....
i have stock cams so i am at the max power my head can flow at the moment, changing the fuel will not make a difference untill i get cams and valve springs.
I aint interested in upgrading the injectors, the nismo's drive great and there is no need to upgrade them. this is a every day car and i am not going to go to big un controlable injectors just for the sake of chasing silly high dyno numbers.
I just want a 10 second quarter and i can achieve that on pump 98, i will go back to e85 once i get that over and done with and put the smaller streetable turbo on.
Got a call from my mate this weekend. He's been running E85 in his 180SX and intended to go for a drive back to the Riverland (SA) for the weekend. Went to get E85 from EFFUE at Mawson Lakes only to be told that they had none! If this keeps happening then E85 is not going to be a realistic option in SA. Very annoying.
Fortunately we still had the tune we did for 98 (he's running Z32 AFM + 740's) so I set him up with a multiple map board and now he can switch between the two. Not quite "flex-fuel" but at least it'll get him out of a bind. Gotta make sure he empties one fuel type before filling with the other that's all...
PL
Hi mate
scotchers race fuels in SA has a 98 blend at the pump $1.70 p/l
Hi mate
Good to know. Looks like a few places that traditionally do race fuels are starting to supply their own E85/98 blends. $1.70 is still a lot more than the mainstream places - but at least you know what you're getting. And it's at the pump - no drums! :D
PL
how does E85 go with storage? the melb place is a bit of a drive for me but if the fuel stores ok, i'll probably fill up a fair bit and keep the rest in my garage.
I probably do about 100km's per week anyway, so i don't drive a lot.
i guess my question, is how long will it last stored? does it go.... "off"?
If you keep E85 in metal drums that are air tight and in a cool dry place, it will last for a couple of years.
Its only when water/moisture gets into it that the shelf life drastically reduces.
Quick update for SA guys. A mate went down to the ENFFUE servo at Mawson Lakes last night and they had E85 for $1.20 per litre. The guy working there said that they had a new supplier and the future looked promising. Make of that what you will.
PL
but at the petrol station i'd take your only option is jerry cans, and from there... do you put it in a metal drum at home?
these hard to find/expensive?
or would a good quality jerry can be ok for a few months?
what afr is it running? my 25 still runs side feed 850cc sard's and are maxed at 380 rwkw on willalls mainline, im pretty sure by the way the map suddenly maxes (crazy rich then snaps lean) out it's a flow issue not the injectors
380rwkw on willall's dyno will be like 400+rwkw or 500+rwhp
that will be a wild ride :cheers:
My af ratio is around high 11 to 12:1 with fuel pressure of around 55psi at idle. Tuner was fairly conservative.
I love how clean the E85 comes out of the exhaust.
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
