It happened to the donut king car at tassie challenge, and I understand its not the only car that has had the problem, or boot floors cracking?
is it true that the body was strengthened between the original and current models?
pretty poor form there considering the amount of testing that should go into a car like this?
When I was a mechanic, we had similar problems with the Lotus Turbos when they first came to Oz.
It is because the bodies are so rigid and our roads are so crap. There is not enough flex int he body, so the next softest thing is glass.
its the shock that the glass experiences, not the bending or flexing...... you can lean against a glass window without anything happening, the glass will concave a little..... have you lightly tapped a spark plug against a sheet of glass????? the shock from the spark plug shatters a massive piece of glass asif it was about to fall apart by itself......
how do you recon those kids break bus shelter glass without a brick or a rock?????
hahahah that would be true beer B but apparently the gears have to hold up to the challenge to make the glass crack...... in the end the same component factory that is making the gear box on the gtr is obviously making the front wind screen lol
horseshit
horseshit
yep, someone doesn't understand, tempering, tension and compression, let alone the difference between a laminated w-screen and a toughened sheet of glass. either way it's horseshit.
Edited by madbung
sorry for stealing thread but since its kinda on topic my 34GT has a cracked windscreen from no obvious reason. no accident, no rock or dents. Only thing i can think of is that my current coilovers are shockingly bouncy ( 19's with low profile and bounce isnt a good combo lol). Can anyone confirm that that would most likely be the reason why my windscreen would crack? if so i cant fix the windscreen without fixing springs...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
