I took my R33 for a wash today and after the was it had so many hairline scratches on it. And i am very Pissed off.
You cant see them easily but they are there and they were not before.
I tried scratch X and it sux. the scratches are so thin and still it couldnt get them off.
I read somewhere i can use Turtle Wax Rubbing Compound, anyone tried it?
or any other ideas.
Please help. I feel shitty.
https://www.sau.com.au/forums/topic/239569-scratches-on-car-from-car-wash/
You mind telling us what the car wash was so we don't make the same mistake? How big a spread are we talking about here like the entire car or like just the bonnet or trunk or something? I would recommend some sort of polish but for the life of me I cant remember what brand, you go to autobarn and they'll tell you if they are really shallow it shouldn't be to hard to get out, I feel for you dude hopefully the solution will be as quick and painless as possible
If you go to your local autoparts store, you'll see a wide range of polishing products.
I generally stick to the Meguiars stuff.
They have products which vary in how agressive they are, from diamond cut, thru to medium cut, light cut and swirl removers. I'd start down at the low end, maybe a light cut and see how you go with that.
Travs right, also usually if you go to a have decent autostore (well the ones I usually go to anyway) and you bring your car usually they will do a small trail on your car to see which grade is best for you
I never use commercial carwashes for the skyline.
Years ago when I worked part time at a servo, the local kids would sneek in and tie sparkplugs to the rotating brushes (you can imagine the damage that caused)
You may need to use a machine rather than hand polish to buff out the marks, then finish witht he finer stuff by hand. Either way its lots of work.
It was the one on albany Highway in cannington, Perth. the one next to Bankwest.
The scratches are all over. On the bonnet, trunk. side. I used to wash my car myself and my car dint have any scratches and yesterday i decided to go to the car wash coz i was lazy.
Thanx for the help guyz. Might got to autobarn and will also check out an autostore.
So what you guyz are sayin is that the scratches can come off for sure? I dont need to repaint or anythin?
they are very tiny scrathes but a lot. you cant see them at times but if you look properly they are there.
Hope they go away. :P
Yeah all carwashes are like that. If you gonna go to one only thing i would do (and i do, do this) is just rinse it with the high pressure soap gun and just spot free rinse it with the gun aswell. Never use the brush in my opinion.
Anywayz bad luck on the trouble Vish and yeah i would follow MintR33's advice and take it to a detialer. Cost you some money but u got pros working on your car, plus you dont have to break your own back aswell.
I just wondered what your technique was when you used the ScratchX. I only ask because if you didn't use it as they intended then you will not get the results they market. I'm definitely not calling you stupid so don't take offence.
I have seen a video of the Meguiar's guys using this and they mentioned that it can give very similar results to using buffing machines, it just takes longer and obviously takes a lot more effort. This doesn depend on how dep the scratches are though. After the paint was clean they worked on a small 30x30cm square and you apply some scratchX to the foam pad and spread it around. Then start to work the product in an up and down motion and then side to side. Keep moving the product from the edges back into the area you're working on. The product has diminishing abrasives in it so the more you work it the finer the particles get.
If you reall want to tell if it is doing something then use some painters tape and put a line of it on the paint and then remove once done and you'll see if you've made an improvement. If you try to large an area you may not achieve much at all. If you do see an improvement but don't get it to exactly how you want try another application on the same area. There is no advantage in letting the ScratchX dry on the paint before you remove it.
Use a clean microfiber towel to remove the product or you might just be adding scratches back into the paint. You'll need to wax the paint after using polishes.
I just thought I'd mention this as it MAY help and if you've already got the ScratchX it doesn't cost you anything.
Edited by Fry_33
Thanx mate. i dint try it that way. will try it when i go home(still at uni).
how the hell do the paint detailers get the paint so nice and shiny and rid the paint of the scratches????
Usually by machine polishing. Most of the time the scratches usually only affect the clear coat. If they're deep enough to be felt with a fingernail then that could be a problem
wow very shiny, amazing. i've only just started taking my 32 through a car wash, usually do it by hand the old fashioned way. we have a "laser car wash" tho, it doesn't touch your car. just sprays soap on, lets it soak, washes it off with high power hoses then repeats with a few different soaps. even washes under your car :P
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
