Hi,
I'm getting the 'mod' jitters again lately and was considering a fmic.
Basically running a SII R33 only mods are turbo back exhaust (split dump, hi flow cat, trust pe2) and a k&n filter.
Was looking at FMIC and boost controller next but was wondering if there are any 'stealth' fmic that will sit under a stock sII front bar which offer good performance??
Any info or pics of what you have done would be great
cheers
https://www.sau.com.au/forums/topic/239922-fmic-for-stock-s2-front-bar/
Hi there also looking for a fmic that will fit nicely behind s2 front bar. I here there is a place in hoppercrossing melb vic that supply a turnaround one as well that fits nicely. I forget the name of the company but thinking about getting one from there. They are also on this forum look in parts for sale section (traders).
thanks for the replies guys.
ok prob bad wording. don't mind a bit of modding to stock s2 front bar. This makes option easier?
keen on seeing pics of what ppl have done and what running.
Found this via google... kinda like the look of what is on it but have no idea what it is or how much modding to get it to fit! http://s134.photobucket.com/albums/q95/mrl...nt=MobyDyno.flv
http://s134.photobucket.com/albums/q95/mrl...ent=mobyimg.jpg
Edited by MAS_R33
Lith's intercooler is just a standard "over the radiator" type.
This is mine:
Its a Blitz LM Kit. Fantastic little piece. Cant be happier.
Note i screwed up the cut a tiny bit on the passenger side, thats why you can see the pipe :) Had a slightly bent bumper iron that i didnt know about when fitting. All fixed now, but after i had trimmed!
But, if you dont screw it up ( :P ) then it looks great!
Edited by gotRICE?
Thanks for the replies.... also thanks for the pic GotRice. Silver R33 is exaclty what i wanted! >_<
I'm not planning on doing the install myself so might talk to the shop and get them to talk me through whats there and exactly how much of my stock front bar needs to be cut.
got rice my car is a splitting image to yours...... how much did you have to cut of your bar? what needed cutting? can you send me more pics of the install or not?????
cheers
These are the only install photos i took. After a bit of frustration i stopped taking snaps :rofl:
Bumper Iron:
Unfortunately i didnt get any photos of the trimming of the bumper itself, as it was pissing me off :), a fair whack of it is cut away, like, nearly all of it. It takes a long time with alot of test fitting, marking, cutting to get it sitting perfect.
And you also need to severely mod the indicator on this style OEM bumper too. Theres barely anything left of it, and the bit of the bumper it slots into was also cut out to clear the intercooler pipe.
Cutting the plastic holder, pulling the brass connectors out etc... you will figure it out!
x 2
I have this one on my car, with a stock S2 bar you won't have to do anything to the foggies or indicators. You need to trim some of the bar on the passengers side under them though. Nothing major. I installed in about 3 or 4 hours over a few beers...
Big tip, bolt it all together, get the pipes sitting properly THEN tighten everything :rofl:
Edit: This type of S2 front bar http://farm3.static.flickr.com/2093/203340...6708a35a8_o.jpg
Edited by Finchy33
If you arent going to upgrade your turbo anytime soon, then why not just get the r34 side mount.
Its capable of supporting 210kw. Direct fit with no modifications!!
I had mine for about a good solid year with no problems. Even been on track days and no problems with heat soak etc.
Will cost you 100 bucks max :rofl:
Thats another option for you :)
gdluck
i wouldnt bother with a side mount
once you turn the boost up and crank up the exhaust i believe the side mount in the side locaiton is a just a big heater panel
i dont believe you get the gains you get from a decent core in the front of the car
ive got a 450x300x75 core and it fits fine, some of the side bar on the s2 bar to be cut back but it fits well
im yet to see in and out temps from a side mount in the side location
i would expect the outtemps after the core arent that crash hot (mind the pun) when 12psi, full exahust and usual GTST mods
for the cost of typical china cores fitted (sub $500 fitted) why would u bother messiing around with side mounts and junk
ok...I never considered a r34 smic. Basically longer term im wanting to running higher boost on the stock turbo (exhaust is already done).
As car is a daily and reliable driver i want to keep it that way, so thought FMIC would be sensible in first step before mucking around.
Finchy33. My front bar is the same as yours. Any chance you have front on pics? I'm liking what your saying about the minor trimming only.
thanks
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
