I'm not entirely sure if this post is on the correct forum but I am just curious as to why a certain percentage of people who place posts on this site appear to have great difficulty in spelling words correctly. Is it a culture thing or is just laziness. Like I said, just curious that's all.
Cheers
And I did'nt even mention grammar.
https://www.sau.com.au/forums/topic/24007-the-written-word/
This is quite funny actually, the other day I was reading a letter (typed) that my boss had just written. The amount of errors was amazing...thing is that he types on forums and in-game so much that it carries over to his work.
I doubt it is laziness in all of you, you still have to type the word so why not spell it right, as mentioned above a lot of the time it is when we type fast so we can answer before someone else, this is when we mess up. My personal favourite/problem is "The" normally I spel it like "teh" .
Its all good though, besides it gives us something to do...first work out what the person is saying then work out if it will work :P
https://www.sau.com.au/forums/topic/24007-the-written-word/#findComment-514358
BOOSTMEISTER's right, it's not laziness. It's a combination of ignorance and illiteracy. Why does it matter? Because English is how we communicate on this forum, not teen speak or l33t speak or whatever the **** it is some people try to pass off as english. You aren't being graded on spelling and grammar, but you will come across as a dumkoph if you can't get the simple things right.
Tolerance is important of course, people for whom english is a second language can be forgiven, but a lot of native english speakers need to put in more effort.
https://www.sau.com.au/forums/topic/24007-the-written-word/#findComment-514492
as long as it makes sense then it's all good...
i tend to type in all lower case, and also not in "proper" sentences on forums... but you can still read what i'm saying.
but when ppl write like 2rismo said:
"wot getz me iz wen dey typ lyk dis n it pisses me of... "
well, I really cbf trying to work out what they're trying to say half the time :P
https://www.sau.com.au/forums/topic/24007-the-written-word/#findComment-514646
In my line of work, i am typing for seven and a half hours straight, for government departments and private sector clients also, and i have to be correct, and fast. If not, i get my ass handed to me. So i find that now when typing anything, from forums to instant messages, my grammar, and spelling are almost perfect. Compared to "type it out as fast as i can, who cares if it's right", where i was before i started working here.
But as others have noted above, as long as it is semi-coherent, and not just a mish-mash of letters, it's all good to me :P
https://www.sau.com.au/forums/topic/24007-the-written-word/#findComment-514649
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
