Sorry Brad, but i think there's some confusion.. looking at your list you've combined both my mates into an SS commodore WRX .. as much as they'd both love a turbo AWD V8.. it's not the case. :thumbsup:
there's me (Steve R32 GTS-T)
Steve621 (my friend Steve WRX)
Kale (SS commodore)
Thanks mate.
  • Replies 124
Bit of a problem...
The helmet I was all set to use is no longer in my house anywhere, is there anyone that can lend me the use of theirs for tomorrow morning?? :P Bastard of a time to find that out haha
Even if you don't mind & aren't going to attend, I can pick it up tonight & drop it back tomorrow, and can donate some Corona to the cause :)
Sorry Brad, but i think there's some confusion.. looking at your list you've combined both my mates into an SS commodore WRX .. as much as they'd both love a turbo AWD V8.. it's not the case. :)
Kale (SS commodore)
Thanks mate.
Steve, ive fixed it. There is now 3 places allocated for you and your 2 mates.
Hope that sorts it out.
hey guys i will be helpin brad run the mornin session
so when u guys arrive if u could come see me , i'll tick ur names off and acknowledge that your present:D
thanks
see u guys sat:)
I was just about to mention that :)
As said, Leo is going to be running the morning session as i cant be there.
Make sure you see him to get your name off the list.
Leo, ill pm you my contact details if you need anything.
umm any reason my name was removed form the list ive payed and what not
I didnt see a payment from you. Its fine, head over there and race. Ill let Leo know.
Leo, give me a call when you can please...i dont have your number.
It can also spin out of control on a consistent basis :)
Good time out there today, the 3rd course we did was great fun. I copped sunburn but not too bad, the only bad thing for me is for some reason that doesn't really make sense, changing from 3rd to 4th makes my gearbox cry....
Top shots man.
Do you mind if I use some of your shots on my FB Stephen, and watermark them with your website and name of course?
Plus I'm also interested in buying the file / or enlarged photo of the R smoking it up.
GTR loves launches and I love losing control just for everyone's enjoyment lol
This round of AHG I definetly improved from the last time. Very keen for another.
    • I neglected to respond to this previously. Get it up to 100 psi, and then you'll be OK.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
