I'm opening a thread again ;)
my car got so many problems now, jeez. :P
If the engine vibrates, the interior starts to making sound (sometimes)
and right hand side door is making squicking sound (often)
I try to go to the dealer to get free maintenance but after 1 or 2 months the sound came back.
Anyone can suggest me shop or people who can check out the car and fix them so that the car won't make any more noise
Thanx
Erik
:D
https://www.sau.com.au/forums/topic/24036-sound-from-door/
dude...u drive a 34 man...i drive a 33 thats knockin close to 7 yrs old now and the squeeks i have in mine, u can only imagine..
as for drivers door, mine used to rattle...i took it off....used electrical tape and taped every f*cken thing and joint together...
even the part at the top of the trim, where it hooks on to the metal frame of the door, i coated it with tape and all so theres no metal against metal henceforth, no chance for rattle.
but!!!
the bloody thing came back and mocked me like a b*tch.
i press it abit now and it goes (klak).
ive pretty much given up till the next time i change my speakers.
https://www.sau.com.au/forums/topic/24036-sound-from-door/#findComment-514996
Lol,
My dad said it's from speaker then I tried to bring it to a shop to fix it then it's gone after a while it came back again.
MrGTST -
It's not when I'm opening the door, it's when I'm driving around.
Angel - Wanna drive? :) When is the next skill swapping day?
streamer - You better get a new r33 like 97's :)
rb25 - lol , I never do such thing , If anyone like to show me how that would be lovely, or it's gonna be a mess job i.e. Take it off and at the end , have no idea how to put it back :D lol
https://www.sau.com.au/forums/topic/24036-sound-from-door/#findComment-515159
oh man :D - theres a total of 6 screws holding my door skin in, theres nothing to these cars, thats the beauty of em..... Just get in there and have a go! :) 12 months ago I didnt know what a turbo looked like, now I'm installing/tuning electronic boost controllers, changing plugs and brakes etc.. Just have a go, you'll learn heaps about your own car.
/end bragging :)
https://www.sau.com.au/forums/topic/24036-sound-from-door/#findComment-515176
erik: its not a difficult job
removing the door trim panels and tightening everything and retaping eveyrthing is the easiest thing ive ever learnt.
door is held by a few screws here and there. im not sure for 34 but i know for 33, its held by 3 screws @ the bottom, a screw in the cup thing attached to yr power window ctrls and your door latch sorround.
the rest is just pins that you can pry off...and pop back in when u push it abck in.
inside yr car, there is a waterproof skin/membrane kinda thing that protects yr trim and electrics frm getting any water durin rainy days or car washes and what happens is often, that is just rubbin against some electrical tape or cables to create a squeak..
so just open em up and see how it goes...shdn't be a problem...
sometimes, its also the the plastic pieces sorrounding the bottom of your dash console..
so if u take that out and tighten everythin and put it back together, shud be fine after that
i tried that too...pretty easy...removing the gear stick and unscrewing the screws behind yr ashtary shd get u started...
laters
https://www.sau.com.au/forums/topic/24036-sound-from-door/#findComment-515227
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
