Looks like somebody has made off with some nice deep dishes or or something there. Hell if I was a Jap teenager I'd be jumping the fence and making off with a nice set of free rims for my rice racer as well..
.. also looks like they've just picked it up via a fork lift (body kit be damned) and dumped it back on the ground...there to sit for another xx months
Any more pix of woa you have?
Originally posted by Soulja
Ha, ha! THAT Celsior is parked right next to my Pajero!!!
Yes folks, that car is on the wharf in Kobe. You can see my Pajero`s tail-light in the second picture on the bottom-left.
Hey predator666, I hope your joking about making off with rims that somebody worked hard to save up money for...
well to settle these "rumours"
that is my car..... i bought it 2 months ago the rims HAVE been replaced (they are very expensive rims) and the body kit will be repaired when the car comes to perth, the insurance company has given me cash to fix it. the window has been replaced and the car has been moved.
It also has a car cover so there is little chance of it getting rusty
P.S yes it was a car off Geoff's mailing list. thankfully he has helped me out with this matter and really helped me out with all my problems to. its a real credit to his business and i wouldn't hesitate to go though him again for my next car.
Originally posted by Jizzmo
1 last thing on the matter,
its NOT free storage it is in an area where it is insured.
so it can happen anywhere.
but hey its all good now so meh
When I saw it, I thought that someone had bought an incomplete car, to reduce the import tax or something...
Just for the record Jizzmo, it`s pretty good inside and out bar the obvoius damage.
Awwww if I hadn't bought my car last year I would have bought that celsior. looks awesome.
Hope you get it back to what it was like.
Too bad it will be in perth and I wont have the chance of seeing it on the road.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
