  • Replies 225
Posted Images
Actually Doof I wouldn't mind to :rofl: if the invitation is there LOL.
Providing the car is running (it isn't currently) then I'm sure it wouldn't be a problem :)
Just have to sort out a small little matter of AN EPIC OIL LEAK!
grrr... I'm no mechanic that's for sure :)
I wouldn't mind putting the 31 on the rollers again.
Can we have a non-turbo and turbo RB30 class, cause for us N/a RB nutters we can get out run by a bloody comonwhore or something like that in the N/a class and we would get toasted in the RB30 class by someone with a turbed 30, just a suggestion.
I'll see if some of the guys from the R31 club would like to come along also.
Interesting... can we rock up on the day or do we have to make 'bookings'
You can just rock up, but the earlier you get there the earlier your car goes on the dyno - first come, first serve.
Ill try to have my new air flow meters on and a retune by then so I can aim for over 300kw, Im definitely in...
Will there be more GTR owners coming to this one then the JEM one? I feel I let the GTR guys down by being the only one there and only getting 254kW
i'm in but at jem they said i had some high end pinging and that thing sitting at the front of the rb25 engine had to be moved clockwise by a mm or something, the guy just loostend the bolts and tapped it around a few times with a spanner and said that should be it...... he didnt re dyno it to see if the pinging did go away....
if its not it and the guys at uas says there some pinging and that thing needs to be moved around again will they do it???? it only takes a minute to do but you need a dyno to know if the prob has been fixed..... i really dont care if they wanna charge me for another dyno run (id rather they didnt charge me for another run) aslong as the prob is fixed because at the moment i'm advised not to let the revs get past 7000rpm or risk damage to the head gaskets or something.....
also should have a fmic by then, mabey a boost controller
Me and Sean will be there we both have R32 GTRs mine was getting tuned at the same time as yours.
That's your crank angle sensor and it adjusts the timing. With too much timing your car can ping. Have you got 98 ron fuel in there?
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
