haha... well it was a secret to me.. full time operations are over rated... a mate of mine went into it... the shit he went through to make it work... and he still hasnt made it profitable as like you say, the money just isnt around here.. he was better off just doing cashies in his garage. there is a list of tools that a workshop must have, it must be a licenced place for a workshop, and the oh&s crap that comes into it.. not to mention all the book work etc.
its sad isnt it... you hear and read about all these hardcore little workshops and race tracks scattered around japan... hours and hours from nowhere... and with some of the most insane machines and a very tight knit crew.... that will never happen here.. people just dont seem to be that passionate... who wants to travel to scone in the hunter valley to get some work done and have some good fun touge runs... not many i bet.
australians have a more hands on approach... everyone has a mate, or knows a guy, who works on this and can get anything cheaper than anyone is selling it for. and because we have shit rules and shit roads... whats the point in spending money on parts and labour of good quality products when you can get a truck turbo, cut down truck core, and a plane fuel pump and have a stonking amount of power for the price of an ebc unit.
australians just cant match the japanese for car tuning... we are good, but everything they do is spot on.
Ok then, looks like the trips to Sydney for work and tuning will always be the case.
Mark Jacobsen (Godzilla Motorsport) often comes down and tunes my car and others. We use a brand new Mainline 4WD dyno and book in a few cars in a day so flying him down from Brisbane is economical...costs are shared between the group. Works out cheaper than going to Sydney and in my opinion his tunes are safer.
Edited by DiRTgarage
When is our thread getting sticky?
just keep bumping it with spotted's...
spotted a gunmetal grey R32 GTR with "Red R Racing" warpaint...numberplates...BBN-70V...sideways at Thornton today. :P
that warpainted gtr does the rounds... i see it in newy fairly often... gave him a wave but either looks down on my 32 gtst or hes just plain arrogant... he saw me too..
Spotted white R33 [GON33E] plates in charlestown, and then coming home 20 minutes later i spotted another wihte R33 with no front bar.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
