Any of you Newcastle guys/girls gonna attend the putty rd cruise to the Imperial hotel in Singleton and have lunch or maybe just drive up to Singleton from newy/the coast for lunch? (I'm only gonna drive half the putty rd and meet them and drive back to singleton) the more cars the better. Here's the info link http://www.skylinesaustralia.com/forums/topic/368709-putty-road-cruise-sunday-31st-july/page__fromsearch__1
Any of you Newcastle guys/girls gonna attend the putty rd cruise to the Imperial hotel in Singleton and have lunch or maybe just drive up to Singleton from newy/the coast for lunch? (I'm only gonna drive half the putty rd and meet them and drive back to singleton) the more cars the better. Here's the info link http://www.skylinesa...__fromsearch__1
Ha! Good stuff Kev. Trying to drum up some interest.
C'mon gang. Get up to Singo and join us for a cruise to the Halfway house to meet the Sydney crew then cruise back up to Singo for lunch. cheers.gif
hey guys,
im chasing a set of coilovers and was hoping that somone in newy may have a set for my latest r32 gts-t,
atm it near looks as high as a land cruiser :yucky:
if so pm me or give me a call im located in valentine
0420 419 267- luke
cheers.
Luke i have an angle grinder :P
Im keen for the cruise but im very forgetfull about these things can someone sms me to keep me informed of when and where to meet up.
Cheers boys
Jez
0414879711
Cheers boys
Jez
0414879711
haha, good old makita lowering kit
Hi Guys
Desperately chasing an R32 GTS-T/GTS4 clutch pedal assembly in newcastle. Current bracket is beyond repair and the car is taking up space at the mechanics until I can find one. tried the toy shop and just jap no luck so far
Dave 0432 579 907
Ha ha so you own the 180 i was eyeing off the cage in it lol i was in there buying up oil for the line and my mates xr8. To bad i was defected on friday night lucky they only got me for my exhuast
Yup that was me. Aha the cage gets more rep than anything else lol. I was there buying some paint for the type x wing I just got which was in the boot. Dang man, lucky ya only got done for the exhaust and nothing else.
Edited by Jay.R34
Hey guys,
Stupid popo are sending me to get a noise test done. Am looking at ways to make my exhaust pass, otherwise anyone have a stock r33 catback i can borrow? Heard a GTST one will do.
Cheers
PM me if its better
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
