spotted a black r33 turning onto donarld st from beaumont about 10am.
and also spotted a bayside blue r34 gtr turning onto lampton rd from bridges rd sometime around lunch time.
That would be me on my way back to work from lunch. :)
Spotted JAP 34R at Tomago
And a white 33 TRIPA just up the road as well
Spotted TRIPA today, looks pretty good! Cruising on Old Punt
Haven't seen any for days then bamm spotted a few this arvo
Black 34 with dark coloured mags at Glendale
White 33 that looked and sounded good heading past the Fire Station at Toronto DAN ???
And a black 32 coming out of the Supacentre
Melisa tells me there is a black 34 that lives just up the road as well near the speed camera
Saw a dark 33 near Aldi in the Terrace... Haven't seen it before....
Seen the regulars around, white 34 4dr, silver 32 with purple rims
Spotted r33 4dr at the terrace again OMT28T I think
Black 4dr r34 gtt cruising near BP Bero
Oh and spotted out famous Humbla 33 parked at a certain spot :woot:
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
