  • 1 year later...
I am trying to find this exact same Question out now?
1. does R32/33 GTR have the same front outer tie rod ends?
2. Do they even make an aftermarket replacement for these or do u have to buy genuine?
3. If as a last resort i have to buy genuine, can anybody reccomend a nissan dealership who is reasonably priced to purchase these from?
any help would be appreciated.
Cheers
Daz.
https://www.sau.com.au/forums/topic/240708-tie-rods/#findComment-5178882
late....but same. I could not find aftermarket (ie reasonably priced) front outer ends. inner end is available and it is most likely to wear (big nylon bush)
aftermarket rear tie rod ends are available, both inner and outer end
https://www.sau.com.au/forums/topic/240708-tie-rods/#findComment-5185778
what brand aftermarket do you get and wea bout in syd you get it from usually?
https://www.sau.com.au/forums/topic/240708-tie-rods/#findComment-5185880
honestly didn't pay any attention to the brand, it was generic korean/chinese/whatever. Have been running them on the race car for about 2 years now so they are good enough quality.
got them through John at UAS, very reasonable price
https://www.sau.com.au/forums/topic/240708-tie-rods/#findComment-5188792
There is play in my front left tie rod. Looks like it's the outer end or the ball and socket that is moving around. Always heard a sound there, and after 3 wheel alignments you'd figure they'd let you know you got play in your steering tie rods :down:
Not sure on the make, but found this front outer tie rod end for skyline online. Duncan you mention the most likely to wear is the inner end which is this one right?
What is the recommended thing to do. To just replace the part that is worn (in my case the front left outer tie rod end... I think :D), or do both outer's and both inners all at the same time, then get the car aligned??
https://www.sau.com.au/forums/topic/240708-tie-rods/#findComment-5194859
yes tht second pic is the bit i mean. there is a nylon socket in there which wears badly. In my experience that is always more worn than the tie rod end
Hmm ok. Took my car to a local shop today. They jacked up the front end and OMG, the amount of play in my left wheel was scary and looked quite dangerous. The movement seemed to be all in the outer tie rod itself and not the inner. So maybe the nylon sockets in mine are ok... or they are on their way out as well. I don't know how to check that. The most the guys have done in the shop is move the wheel. You can see how much it moves, and from the inside you can see the ball socket outer tie rod thingy moving around as well. Not sure what to do next.
The other side of the car I've been told is perfectly fine. But I'm feeling like maybe I should just buy 2 of them, and get them both done.
https://www.sau.com.au/forums/topic/240708-tie-rods/#findComment-5201992
  • 1 month later...
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
