Andrew Sanders at Specialised Power Porting is the only place in OZ that I understand currently does this.
I have used his services on my exhaust manifold, intake manifold and compressor cover. From memory, 4 cylinder manifolds (intake or exhaust) were $550 each and comp cover around $300. Obviously these prices may have changed and will be more for 6 cylinder manifolds.
https://www.sau.com.au/forums/topic/240906-extrude-honing/#findComment-4206860
Based purely on a power figure I'd agree, but has anyone measured the efficiency maybe as a fuel consumption figure?
If something flows better, it has to have benefit somewhere, even lower rpm for boost gains maybe?
https://www.sau.com.au/forums/topic/240906-extrude-honing/#findComment-4207799
One of the advantages is extrude honing allows you to flow balance each runner as well as improve flow overall. For instance my sr20 intake manifold was all over the place and when extrude honed the runners all flowed within a few cfm of each other. Not to mention it also picked up nearly 50cfm of flow on the poorest flowing runner. Unfortunately I had a change of heart and am now installing a Hypertune manifold so I can't say what the real world results might have been with the extrude honed unit.
Edited by juggernaut1
https://www.sau.com.au/forums/topic/240906-extrude-honing/#findComment-4208624
When I rang this place (about 15 months ago) he no longer did extrude honing as he had leased/sold his dies and gear to someone else. I think Unique Autosports used to use his services because when I ran Unique about the same time they also advised me they were no longer able to get manifolds extrude honed. Things may have changed now tho'.
https://www.sau.com.au/forums/topic/240906-extrude-honing/#findComment-4208892
There was a thread on an extrude honed RB25 stock exhuast manifold and no real gains were recorded. Most likely the money can be better spent elsewhere.
Yeah that was my little experiment. From what i learned it depends on what turbo/power your going to run which will help you decide if honing the manifold will be worth it.
https://www.sau.com.au/forums/topic/240906-extrude-honing/#findComment-4210442
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
