I'm thinkin' of blocking off my standard BOV in my 32 so I get the flutter but I've been told different stories my people.
Does anyone know FOR A FACT if it does any damage/excessive strain to the turbo? Or is it absolutely safe to do?
https://www.sau.com.au/forums/topic/240998-blocking-off-bov/
  • Replies 188
I have a piece of a compressor wheel from a rb20 turbo which blew out of my friends exhaust.
He blocked off his bov and was running 14psi..
Whether it was the blocked bov or the 14psi, i still have a cool looking piece of ceramic :/
ive had mine blocked off for a while now however i only blocked it off as my stock one was leaking under boost...ive recently bought a greddy type s bov..got it off a mate cheap and only bought that one coz couldnt get my hands on a gtr bov..
but the fluttering is fine...i still remember driving past some yr 8 skool kids and letting the flutters go off lol all i could here from the kiddies was ohhh woooww hehe i a had abig grin then lol
i don't think it'll effect it much if you're running standard boost! but if you start uping the boost it'll be safer to leave the bov the way it is!
and if you want a flutter you can get an aftermarket one and tighten it
That's exactly what I think! That's why I'm unsure.
lots of cars dont have them and run fine. mine never had one from factory. u know why manufactures use bov's now..? noise polution. they dont want weird tu tu noises coming form their engines. the average person buying a car would be like wtf that aint right. thats why some cars come with 4 cats in their exhaust systems when only one is required. to keep cars running smooth and quiet.
Edited by steveP
The reverse flow back across the turbo acts on the compressor wheel and causes the turbine shaft to reduce in speed quicker than it would naturally. When the throttle is opened again, the turbo will have to make up for lost momentum and will take longer to achieve the required speed, as turbo speed is proportional to boost/volume flow. (This is known as Turbo Lag) In order to prevent this from happening, a valve is fitted between the turbo and inlet which vents off the excess air pressure. These are known as an anti-surge, bypass, blow-off (BOV) or dump valve. They are normally operated by engine vacuum.
but a bov releases all the air. with no bov, the air between the turbo and throttle body gradually escapes back out the intake system. during gear change or whatever, theres still boost in the intake pipes/cooler, so it wont need to spool up all over again.
and before someone goes emo and cuts themselves saying it damages ur turbo. turbos are very robust. they handle high boost pressure and extreme heat for 100,000+kms (average life of a turbo). so releasing the air back out the intake system 'a little slower' is going to do f**k all to a turbo.
Edited by steveP
That is from the 14psi through a stock turbo, Blow off valve will not effect the rear wheel nor will it effect the front wheel as much as you think. The main concern when not using a BOV is because the sudden surge of back pressure puts strain on the bearing and seals inside the turbo from the back and forth movement it will get during this time. A blocked Air filter can also cause alot of wear.
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
