Time For An Emsta/krzysiu Organised Event
Event
53 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 68
....I hate you guys.....I've been eating Asian....(Not Asians....) for the past 16yrs of my life, I finally get freedom and now you want me to start up again!??! How about Hungry Jacks?! Anybody Anybody? How about Thai, or Steak, or BBQ, or KFC, or Micky D's or,....ANYTHING!? *sigh* if you guys want chinese so bad I guess......Man some of you just need to get Chinese GF's....I'm not saying or BF's for a reason...you think we can cook?! buy anyway I'm down for what ever hope to see you soon...Oh i know should put down Guitar Hero as an option! Lol jk
Guitar Hero party at James' house. Sweet, im in. How many people are coming again? :blink:
Guitar Hero party at James' house. Sweet, im in. How many people are coming again? :D
Hey just putting it out there GH at my house is definitely an option and if were not driving (or up to .05) alcohol is welcome as well
Yo can I get on in this organizing deali-o? Hahahah na man so we have a guesstimate date yet? Wow holy crap guesstimate is actually a word in my Firefox's dictionary....never knew that lol
james - i wanna plan this before xmas. So late nov/early dec.
Since most people wanna meet n greet + cruise - maybe during the day.... I am currently thinking of the following:
- a cruise along the beach - and stopping at the marina to take pics (the supra club had something like this a while back, was a great turn out)
- black spurs cruise
- mt dandy cruise
- great ocean rd cruise
- winery cruise
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
